[PATCH] Updated Legacy code in arm edb7312
Vipul Nayyar
nayyar_vipul at yahoo.com
Tue Jul 9 13:33:43 UTC 2013
c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c | 49 +++++++++++---------------
c/src/lib/libbsp/arm/edb7312/network/network.c | 27 +++++++++-----
2 files changed, 39 insertions(+), 37 deletions(-)
diff --git a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
index bd77dd6..9ba4311 100644
--- a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
+++ b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
@@ -12,24 +12,14 @@
#include <ep7312.h>
#include <bsp.h>
#include <bsp/irq.h>
+#include <assert.h>
#if ON_SKYEYE==1
#define CLOCK_DRIVER_USE_FAST_IDLE
#endif
void Clock_isr(rtems_irq_hdl_param arg);
-static void clock_isr_on(const rtems_irq_connect_data *unused);
-static void clock_isr_off(const rtems_irq_connect_data *unused);
-static int clock_isr_is_on(const rtems_irq_connect_data *irq);
-rtems_irq_connect_data clock_isr_data = {
- .name = BSP_TC1OI,
- .hdl = Clock_isr,
- .handle = NULL,
- .on = clock_isr_on,
- .off = clock_isr_off,
- .isOn = clock_isr_is_on,
+uint32_t clock_driver_get_nanoseconds_since_last_tick(void);
#define Clock_driver_support_at_tick() \
do { \
@@ -37,9 +27,17 @@ rtems_irq_connect_data clock_isr_data = {
} while(0)
#define Clock_driver_support_install_isr( _new, _old ) \
+ rtems_status_code status = RTEMS_SUCCESSFUL; \
do { \
(_old) = NULL; /* avoid warning */; \
- BSP_install_rtems_irq_handler(&clock_isr_data); \
+ status = rtems_interrupt_handler_install( \
+ BSP_TC1OI, \
+ "Clock", \
+ RTEMS_INTERRUPT_UNIQUE, \
+ Clock_isr, \
+ NULL \
+ assert(status == RTEMS_SUCCESSFUL); \
} while(0)
@@ -60,9 +58,15 @@ rtems_irq_connect_data clock_isr_data = {
*EP7312_TC1EOI = 0xFFFFFFFF; \
} while (0)
-#define Clock_driver_support_shutdown_hardware() \
- do { \
- BSP_remove_rtems_irq_handler(&clock_isr_data); \
+#define Clock_driver_support_shutdown_hardware() \
+ do { \
+ status = rtems_interrupt_handler_remove( \
+ BSP_EINT3, \
+ Clock_isr, \
+ NULL \
} while (0)
@@ -76,17 +80,4 @@ uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
#define Clock_driver_nanoseconds_since_last_tick \
- return 1;
#include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/arm/edb7312/network/network.c b/c/src/lib/libbsp/arm/edb7312/network/network.c
index 1db4d02..807166e 100644
--- a/c/src/lib/libbsp/arm/edb7312/network/network.c
+++ b/c/src/lib/libbsp/arm/edb7312/network/network.c
@@ -2,18 +2,13 @@
#include <sys/mbuf.h>
#include <libchip/cs8900.h>
#define CS8900_BASE 0x20000300
unsigned int bsp_cs8900_io_base = 0;
unsigned int bsp_cs8900_memory_base = 0;
cs8900_device *g_cs;
void cs8900_isr(rtems_irq_hdl_param unused);
-rtems_irq_connect_data cs8900_isr_data = {BSP_EINT3,
- cs8900_isr,
- NULL,
- NULL,
- NULL,
- NULL};
char g_enetbuf[1520];
@@ -68,13 +63,29 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg)
void cs8900_attach_interrupt (cs8900_device *cs)
g_cs = cs;
- BSP_install_rtems_irq_handler(&cs8900_isr_data);
+ BSP_EINT3,
+ "Network",
+ cs8900_isr,
+ NULL
void cs8900_detach_interrupt (cs8900_device *cs)
- BSP_remove_rtems_irq_handler(&cs8900_isr_data);
+ BSP_EINT3,
+ cs8900_isr,
+ NULL
unsigned short cs8900_get_data_block (cs8900_device *cs, unsigned char *data)
1.7.11.7
