[GSoC] libmm project status
Gedare Bloom
gedare at rtems.org
Tue Jul 9 17:13:23 UTC 2013
And at least one of the mm tests.
On Tue, Jul 9, 2013 at 1:09 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Tue, Jul 9, 2013 at 7:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> When we do the initial commit of libmm, we should link every BSP/CPU
>> to the nop stub implementation. We can probably get started on merging
>> that baseline soon. Hesham, if you can pull out a patch containing
>> just the nop implementation we can review it.
> A patch To include the stubs and high-level headers for every BSP and
> changes to all Makefile.am only ?
>> On Tue, Jul 9, 2013 at 12:53 PM, Hesham Moustafa
>> > On Tue, Jul 9, 2013 at 6:47 PM, Rempel, Cynthia
>> > <cynt6007 at vandals.uidaho.edu> wrote:
>> >> >>Is there a way to conditionally build the mmtests based on whether
>> >> >> libmm
>> >> >> is being built?
>> >> >>My initial thought is something like an AM_CONDITIONAL
>> >> >> >> >>http://www.gnu.org/software/automake/manual/html_node/Subdirectories-with-AM_005fCONDITIONAL.html
>> >> >>Although another way to conditionally build the tests may be
>> >> >> better...
>> >> >>Ideally if we went that route (and if feasible), if there was a
>> >> >> conditional being used for building libmm, we would use the same
>> >> >> conditional
>> >> >> for the libmm tests...
>> >> >Sure, I can work on that.
>> >> Thanks!
>> >> My main concern is if a BSP doesn't have libmm built, will building all
>> >> the tests lead to a compiler / linker error?
>> >> If not, we needn't worry about building conditionally...
>> > There are stubs for libmm functions at a high-level APIs at
>> > no_memorymanagement.c file. So, every BSP/CPU that does not implement
>> > libmm
>> > functions can be built without error with including that file.
>> >> I'm mostly worried about getting these tests committed incrementally if
>> >> feasible (i.e. they don't break the build)...
>> >> Hopefully we can get your work committed over the summer and reduce the
>> >> number of patches at the end of the summer :)
>> >> I noticed there wasn't a copyright on the .doc s. Could you add
>> >> # COPYRIGHT (c) 2013.
>> >> # Hesham Moustafa.
>> >> # The license and distribution terms for this file may be
>> >> # found in the file LICENSE in this distribution or at
>> >> # http://www.rtems.com/license/LICENSE.
>> >> To the top of
>> >> mmtest1/mmtest1.doc
>> >> mmtest2/mmtest2.doc
>> >> mmtest3/mmtest3.doc
>> >> Thanks!
>> >> Cindy
>> >> ________________________________________
>> >> From:
>> >> rtems-devel-bounces at rtems.org<mailto:rtems-devel-bounces at rtems.org>
>> >> [rtems-devel-bounces at rtems.org<mailto:rtems-devel-bounces at rtems.org>]
>> >> on
>> >> behalf of Rempel, Cynthia
>> >> [cynt6007 at vandals.uidaho.edu<mailto:cynt6007 at vandals.uidaho.edu>]
>> >> Sent: Monday, July 08, 2013 3:55 PM
>> >> To: Hesham Moustafa;
>> >> rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
>> >> Cc: Gedare Bloom
>> >> Subject: RE: [GSoC] libmm project status
>> >> Hi,
>> >> Thanks for providing the link directly to the testcases!
>> >> Could you copy the information about each test into:
>> >> mmtest1/mmtest1.doc
>> >> Simple tests that tries to install memory management entries
>> >> mmtest2/mmtest2.doc
>> >> + Install entries with specific memory attributes (e.g read only
>> >> region) :
>> >> + Check for memory protection violations (writing to read only blocks)
>> >> + Reading from read only blocks.
>> >> + Write/Read to/from unmapped region (error!).
>> >> + Write to a valid entry that was installed and then uninstalled
>> >> (error!).
>> >> mmtest3/mmtest3.doc
>> >> + Tests for libmm behavior on SMP environments.
>> >> + Create tasks for each core and start it.
>> >> + Check for memory consistency and page tables and memory attributes
>> >> validity.
>> >> That way we can quickly identify what each test does in 5 years... Good
>> >> job with the documentation :)
>> >> Cindy
>> >> From:
>> >> on
>> >> behalf of Hesham Moustafa
>> >> [heshamelmatary at gmail.com<mailto:heshamelmatary at gmail.com>]
>> >> Sent: Monday, July 08, 2013 3:39 PM
>> >> To: rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
>> >> Cc: Gedare Bloom
>> >> Subject: [GSoC] libmm project status
>> >> Hi all,
>> >> I have posted a new thread to my blog that contains a brief
>> >> introduction
>> >> to libmm and latest updates, here is the thread [1] Please take a look.
>> >> TODO: port libmm for Raspberry PI board on real hardware.
>> >> Questions :
>> >> I have created a new test case at libtests called mmtest3 [2] which
>> >> simulate SMP use case on QEMU/Realview. It simply tries to invoke the
>> >> same
>> >> task (which calls libmm function) for each core. There is a fatal error
>> >> at
>> >> startup that branches to data exception handler but I am not sure why.
>> >> Please take a look and tell me if I am doing something wrong with that
>> >> test
>> >> case.
>> >> Other test cases (mmtest1, mmtest2) run successfully on the same
>> >> platform.
>> >> [1]
>> >> http://heshamelmatary.blogspot.com/2013/07/gsoc-2013-libmm-for-rtems.html
>> >> [2]
>> >> https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm/testsuites/libtests/mmtest3
>> >> Regards,
>> >> Hesham
>> >> _______________________________________________
>> >> rtems-devel mailing list
>> >> http://www.rtems.org/mailman/listinfo/rtems-devel
