[PATCH] Updated Legacy code in arm gumstix
Vipul Nayyar
nayyar_vipul at yahoo.com
Tue Jul 9 14:52:10 UTC 2013
Hello,
Some points on which I needed clarification :
1) I've used rtems_irq_hdl to pass handle to ne_interrupt_on() function. Is that correct or should I use some other data type.
2) Functions like ne_interrupt_off() & ne_interrupt_is_on() are not used anywhere, but still I didn't get any warnings. Should I remove them ?
Regards
Vipul Nayyar
________________________________
To: rtems-devel at rtems.org
Sent: Tuesday, 9 July 2013 8:16 PM
Subject: [PATCH] Updated Legacy code in arm gumstix
c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c | 33 +++++++++++++-------------
1 file changed, 16 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c b/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
index 5db0433..bef6560 100644
--- a/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
+++ b/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
@@ -350,9 +350,9 @@ ne_interrupt_handler (rtems_irq_hdl_param handle)
/* Turn NE2000 interrupts on. */
static void
-ne_interrupt_on (const rtems_irq_connect_data *irq)
+ne_interrupt_on (const rtems_irq_hdl handle)
- struct ne_softc *sc = irq->handle;
+ struct ne_softc *sc = handle;
#ifdef DEBUG_NE
printk ("ne_interrupt_on()\n");
@@ -364,9 +364,9 @@ ne_interrupt_on (const rtems_irq_connect_data *irq)
/* Turn NE2000 interrupts off. See ne_interrupt_on. */
static void
-ne_interrupt_off (const rtems_irq_connect_data *irq)
+ne_interrupt_off (const rtems_irq_hdl handle)
#ifdef DEBUG_NE
printk ("ne_interrupt_off()\n");
@@ -380,9 +380,9 @@ ne_interrupt_off (const rtems_irq_connect_data *irq)
*If it is eanbled, return 1
static int
-ne_interrupt_is_on (const rtems_irq_connect_data *irq)
+ne_interrupt_is_on (const rtems_irq_hdl handle)
unsigned char imr;
#ifdef DEBUG_NE
printk("ne_interrupt_is_on()\n");
@@ -479,21 +479,20 @@ ne_init_hardware (struct ne_softc *sc)
static void
ne_init_irq_handler(struct ne_softc *sc)
- rtems_irq_connect_data irq;
+ rtems_status_code status = RTEMS_SUCCESSFUL;
#ifdef DEBUG_NE
printk("ne_init_irq_handler(%d)\n", sc->irno);
#endif
- irq.name = sc->irno;
- irq.hdl = ne_interrupt_handler;
- irq.handle = sc;
- irq.on = ne_interrupt_on;
- irq.off = ne_interrupt_off;
- irq.isOn = ne_interrupt_is_on;
- if (!BSP_install_rtems_irq_handler (&irq))
- rtems_panic ("Can't attach NE interrupt handler for irq %d\n", sc->irno);
+ status = rtems_interrupt_handler_install(
+ sc->irno,
+ "RTL8019",
+ RTEMS_INTERRUPT_UNIQUE,
+ ne_interrupt_handler,
+ sc
+ assert(status == RTEMS_SUCCESSFUL);
+ ne_interrupt_on(sc);
/* The NE2000 packet receive daemon. This task is started when the
NE2000 driver is initialized. */
1.7.11.7
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130709/3fc8e318/attachment.html>
