[PATCH] Updated Legacy code in arm gumstix
Wed Jul 10 08:21:17 UTC 2013
On 07/09/2013 04:52 PM, Vipul Nayyar wrote:
> Some points on which I needed clarification :
> 1) I've used rtems_irq_hdl to pass handle to ne_interrupt_on() function. Is
> that correct or should I use some other data type.
This type belongs to the legacy API.  Simply use void *.
> 2) Functions like ne_interrupt_off() & ne_interrupt_is_on() are not used
> anywhere, but still I didn't get any warnings. Should I remove them ?
If you replace the BSP_install_rtems_irq_handler(), then you have to add the on
handler after the rtems_interrupt_handler_install().
If you replace the BSP_remove_rtems_irq_handler, then you have to add the off
handler before the rtems_interrupt_handler_remove().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
