Running rtems-sample applications in lpc2478 OEM board
CHINTHA MOL C.S. chintha308 at gmail.com
Wed Jul 10 12:24:51 UTC 2013
Hi ,
I would like to run rtems sample applications in lpc2478 (ARM7) OEM board.
Now i am trying to run the hello world sample application. Loaded the
hello.ralf in SDRAM via debug tool.
In RTEMS sample application, UART 0 is configured as console driver.
FTDI driver is installed in my PC.Baud rate set for the new virtual COM
port is  115200.
But while running the application junk data is coming in hyper terminal
window ..
Could you please give  guidance to run rtems sample applications in lpc2478
OEM board.
Regards,
Chintha
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130710/20811368/attachment.html>
