[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar nayyar_vipul at yahoo.com
Wed Jul 10 17:44:10 UTC 2013
 c/src/lib/libbsp/arm/rtl22xx/network/network.c | 25 +++++++++++++++++--------
 1 file changed, 17 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libbsp/arm/rtl22xx/network/network.c b/c/src/lib/libbsp/arm/rtl22xx/network/network.c
index 3b54862..8cff6b1 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/network/network.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/network/network.c
@@ -3,18 +3,13 @@
 #include <sys/mbuf.h>
 #include <bsp/irq.h>
 #include <libchip/cs8900.h>
+#include <assert.h>
 #define CS8900_BASE 0x20000300
 unsigned int bsp_cs8900_io_base = 0;
 unsigned int bsp_cs8900_memory_base = 0;
 cs8900_device *g_cs;
 void cs8900_isr(rtems_irq_hdl_param unused);
-rtems_irq_connect_data cs8900_isr_data = {LPC22xx_INTERRUPT_EINT2,
-                                         cs8900_isr,
-					  NULL,
-					  NULL,
-					  NULL,
-					  NULL};
 char g_enetbuf[1520];
@@ -69,13 +64,27 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg)
 void cs8900_attach_interrupt (cs8900_device *cs)
+    rtems_status_code status = RTEMS_SUCCESSFUL;
     g_cs = cs;
-    BSP_install_rtems_irq_handler(&cs8900_isr_data);
+    status = rtems_interrupt_handler_install(          \
+        LPC22xx_INTERRUPT_EINT2,                                     \
+        "Network",                                       \
+        RTEMS_INTERRUPT_UNIQUE,                        \
+        cs8900_isr,                                     \
+        NULL                                           \
+    assert(status == RTEMS_SUCCESSFUL);
 void cs8900_detach_interrupt (cs8900_device *cs)
-    BSP_remove_rtems_irq_handler(&cs8900_isr_data);
+    rtems_status_code status = RTEMS_SUCCESSFUL;    \
+    status = rtems_interrupt_handler_remove(        \
+        cs8900_isr,                                  \
+        NULL                                        \
 unsigned short cs8900_get_data_block (cs8900_device *cs, unsigned char *data)
1.7.11.7
