[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar
nayyar_vipul at yahoo.com
Fri Jul 12 19:45:08 UTC 2013
If I don't need that intermediate variable, then my previous patch containing
void cs8900_isr(cs8900_device *cs){
cs8900_interrupt(LPC22xx_INTERRUPT_EINT2, cs);
,should be correct right ?
I followed the flow of bsp_interrupt_handler_dispatch() & where it leads, but couldn't figure out much. Will try again tomorrow.
I still don't understand what mistake I'm doing regarding removing superfluous entities from the code. :-(
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Saturday, 13 July 2013 1:00 AM
Subject: Re: [PATCH] Updated Legacy code in arm rtl22xx
On 12/07/13 17:30, Vipul Nayyar wrote:
> Ok, So before sending the updated patch I'll list in advance what I'm gonna change, so that we don't have to go through this again.
> 1) Change cs8900_isr to static. The sample code would be:
> static void cs8900_isr(void *arg)
> cs8900_device *cs = arg;
This is all right in principle, but you don't need the intermediate
variable.
Now the questions are:
1. Who will call this function?
2. Where does the actual arg argument value come from?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130713/0d9cd401/attachment.html>
