[PATCH] Updated Legacy code in arm rtl22xx
Fri Jul 12 20:04:45 UTC 2013
On 12/07/13 21:45, Vipul Nayyar wrote:
> If I don't need that intermediate variable, then my previous patch containing
> void cs8900_isr(cs8900_device *cs){
>   cs8900_interrupt(LPC22xx_INTERRUPT_EINT2, cs);
> ,should be correct right ?
No, because here you have now the wrong function type.  What you need is
this:
static void cs8900_isr(void *arg)
   cs8900_interrupt(LPC22xx_INTERRUPT_EINT2, arg);
> I followed the flow of bsp_interrupt_handler_dispatch() & where it leads, but couldn't figure out much. Will try again tomorrow.
> I still don't understand what mistake I'm doing regarding removing superfluous entities from the code. :-(
You should take the time to understand how the generic interrupt
framework works.  You can compile for example the realview_pbx_a9_qemu
BSP and run it on Qemu.  Set a break point to
bsp_interrupt_handler_dispatch() and see what happens if you single step
with the debugger though it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
