[GSOC] Help regarding deleting unused functions
Mon Jul 15 08:44:50 UTC 2013
On 07/14/2013 10:01 AM, Vipul Nayyar wrote:
> While doing my current task of removing legacy code, after compilation, I
> receive warnings for a certain function, that is defined but not used. As
> suggested by Sebastian, I delete it, after checking whether it's really been
> not called anywhere in the current file, and outside it. Most of the functions
> that I'm talking about right now are static, or supposed to be static.
> After re-compilation, warning for that deleted function is obviously gone, but
> there are new warnings of functions defined but not used. So, ultimately I have
> to delete these static functions who are inter-related(calling each other), in
> order to remove the warnings. Currently I was trying my hand on i386 pc386 BSP,
> where I encountered this thing.
> I really don't know whether deleting these multiple inter-related static
> functions is the right way to go or a horribly wrong one.
In case the unused functions appear due to the interrupt API changes you can
recursively delete all defined but unused functions (you get this warning only
for static functions).  You only have to make sure that you don't delete
non-trivial on/off handlers.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
