[PATCH] Updated Legacy code in i386 pc386
Vipul Nayyar
nayyar_vipul at yahoo.com
Wed Jul 24 10:08:27 UTC 2013
Hello,
I put (rtems_interrupt_handler) casts because I was getting warnings. After I removed them now, I think it's working fine. Don't know how.
The indentation around line 684 in 3c509.c is surely correct. It's following the same indentation as above line 'resend = 0;' Have a look.
I removed the Clock_driver_support_at_tick_empty function because it was empty. So I think my current edit should suffice . Right ?
Passed sc directly to interrupt handler.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: rtems-devel at rtems.org
Sent: Wednesday, 24 July 2013 1:06 PM
Subject: Re: [PATCH] Updated Legacy code in i386 pc386
Hello Vipul,
can you please remove all the (rtems_interrupt_handler) casts.
On 2013-07-23 17:03, Vipul Nayyar wrote:
> @@ -746,8 +681,8 @@ int rtems_3c509_driver_attach (struct rtems_bsdnet_ifconfig *config )
> overrun = 0;
> resend = 0;
> - ep_unit = 0;
> - ep_boards = 0;
> + ep_unit = 0;
> + ep_boards = 0;
Here the indentation is wrong, please check other parts of the patch as well.
> @@ -326,7 +309,7 @@ void Clock_driver_support_initialize_hardware(void)
> if ( use_8254 ) {
> /* printk( "Use 8254\n" ); */
> - Clock_driver_support_at_tick = Clock_driver_support_at_tick_empty;
> + Clock_driver_support_at_tick = NULL;
What is the reason for this change?
> @@ -381,7 +381,7 @@ ne_check_status (struct ne_softc *sc, int from_irq_handler)
> /* Handle an NE2000 interrupt. */
> static void
> -ne_interrupt_handler (rtems_irq_hdl_param cdata)
> +ne_interrupt_handler (void * cdata)
> rtems_vector_number v = (rtems_vector_number) cdata;
> struct ne_softc *sc;
I think you can get rid of ne_device_for_irno if you use the right cdata value
(e.g. pass directly sc).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130724/6c032af2/attachment.html>
