bootstrap is slow and issues many warnings
Wed Jul 24 15:52:30 UTC 2013
R. Diez wrote:
>> $ ~/development/rtems/4.11/bin/automake --version
>> automake (GNU automake) 1.12.6
>> What happens if you try this version ?
> I am not getting any warnings with automake versions 1.12.6 or 1.13.4.
Great.
> The process remains rather slow in any case. Is there any way to speed it up?
Normally it is just something done once or after an update. There is a
tool called sb-bootstrap in the RSB [1] that runs the reconfigures in
parallel on as many cores as you have. Other than that there is little
we can do while we stay with autoconf and automake as a build system.
[1]
http://git.rtems.org/rtems-source-builder/tree/source-builder?id=6d32fe7eb0388698ab07726229e769cd9bb30134
