[PATCH] Removed legacy data types from arm
Vipul Nayyar nayyar_vipul at yahoo.com
Wed Jul 24 17:49:51 UTC 2013
 c/src/lib/libbsp/arm/csb336/console/uart.c    | 16 ++++++++--------
 c/src/lib/libbsp/arm/csb336/network/network.c |  4 ++--
 c/src/lib/libbsp/arm/csb337/network/network.c |  4 ++--
 3 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
index 0f6388b..d3d8972 100644
--- a/c/src/lib/libbsp/arm/csb336/console/uart.c
+++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
@@ -40,10 +40,10 @@ static void _BSP_output_char(char c);
 static int _BSP_poll_char(void);
 #if USE_INTERRUPTS
-static void imx_uart_tx_isr(rtems_irq_hdl_param);
-static void imx_uart_rx_isr(rtems_irq_hdl_param);
-static void imx_uart_isr_on(const rtems_irq_number);
-static void imx_uart_isr_off(const rtems_irq_number);
+static void imx_uart_tx_isr(void *);
+static void imx_uart_rx_isr(void *);
+static void imx_uart_isr_on(rtems_vector_number);
+static void imx_uart_isr_off(rtems_vector_number);
 static ssize_t imx_uart_intr_write(int, const char *, size_t);
 static rtems_vector_number imx_uart_name_transmit(int minor);
 static rtems_vector_number imx_uart_name_receive(int minor);
@@ -328,16 +328,16 @@ static int imx_uart_set_attrs(int minor, const struct termios *t)
 #if USE_INTERRUPTS
-static void imx_uart_isr_on(const rtems_irq_number name)
+static void imx_uart_isr_on(rtems_vector_number name)
     MC9328MXL_AITC_INTENNUM = name;
-static void imx_uart_isr_off(const rtems_irq_number name)
+static void imx_uart_isr_off(rtems_vector_number name)
     MC9328MXL_AITC_INTDISNUM = name;
-static void imx_uart_rx_isr(rtems_irq_hdl_param param)
+static void imx_uart_rx_isr(void * param)
     imx_uart_data_t *uart_data = param;
     char buf[32];
@@ -351,7 +351,7 @@ static void imx_uart_rx_isr(rtems_irq_hdl_param param)
     rtems_termios_enqueue_raw_characters(uart_data->tty, buf, i);
-static void imx_uart_tx_isr(rtems_irq_hdl_param param)
+static void imx_uart_tx_isr(void * param)
     int len;
diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
index f93fcc8..b233143 100644
--- a/c/src/lib/libbsp/arm/csb336/network/network.c
+++ b/c/src/lib/libbsp/arm/csb336/network/network.c
@@ -39,7 +39,7 @@
 /* RTEMS event used to start transmit daemon. */
 #define START_TRANSMIT_EVENT    RTEMS_EVENT_2
-static void enet_isr(rtems_irq_hdl_param);
+static void enet_isr(void *);
 static void enet_isr_on(void);
 typedef struct {
@@ -658,7 +658,7 @@ mc9328mxl_enet_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
 /* interrupt handler */
-static void enet_isr(rtems_irq_hdl_param unused)
+static void enet_isr(void * unused)
     uint16_t int_reg;
diff --git a/c/src/lib/libbsp/arm/csb337/network/network.c b/c/src/lib/libbsp/arm/csb337/network/network.c
index 9e0a4be..ba3c524 100644
--- a/c/src/lib/libbsp/arm/csb337/network/network.c
+++ b/c/src/lib/libbsp/arm/csb337/network/network.c
@@ -83,7 +83,7 @@
-static void at91rm9200_emac_isr (rtems_irq_hdl_param unused);
+static void at91rm9200_emac_isr (void *);
 static void at91rm9200_emac_isr_on(void);
 /* use the values defined in linkcmds for our use of SRAM */
@@ -826,7 +826,7 @@ at91rm9200_emac_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
+static void at91rm9200_emac_isr (void * unused)
     unsigned long status32;
1.7.11.7
