How to port to the Arduino Due with C++ exception support etc.
Thu Jul 25 14:38:31 UTC 2013
Hello,
On 2013-07-24 15:19, R. Diez wrote:
> Hi all:
> [2nd attempt at posting this message]
> I am tired of old-style C code and their accompanying
> decade-old excuses in embedded environments, so I have set up an
> open-source, bare-metal environment for the Arduino Due with support for
>   "modern" C++ features like C++ exceptions. For more information, see
> here:
> https://github.com/rdiez/JtagDue
> The
>   next step would be upgrading to a proper OS with POSIX threads etc.,
> while still keeping C++ exception support and the like. I hope RTEMS
> does not disappoint me.
RTEMS is a good choice if you need a small operating system with POSIX threads
support.
> The Arduino Due has an AT91SAM3X8E
> microcontroller with an ARM Cortex-M3 core, 512 KiB Flash and 96 KiB
> SRAM. However, RTEMS does not have a Board Support Package for this
> board. What would be the best way to write a new one, in order to
> prevent as much duplication as possible?
> I had a quick look around, and I found the following candidate Board Support Packages:
> - stm32f4: Cortex-M4, looks simple and small, probably a good template.
> - lm3s69xx: Supports some Cortex-M? CPU.
Both BSPs use the Cortex-M.  Providing a BSP for the Cortex-M is quite simple
since they all have the NVIC and SysTick modules.  Only the console driver is
likely chip dependent.
One of the lm3x69xx variants runs on Qemu.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
