Development Work For RTEMS
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Thu Jul 25 15:17:35 UTC 2013
Hi Christopher Kerl,
The http://www.rtems.org/wiki/index.php/GoogleCodeInProjects#Finish_a_POSIX_API_Chapter would be entry-level documentation...
You would check out the rtems.git and be editing files in the rtems/tree/doc/posix_users directory...
Hope this helps!
Cindy
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of zargy [zargyyoyo at gmail.com]
Sent: Wednesday, July 24, 2013 7:47 PM
To: rtems-devel at rtems.org
Subject: Re: Development Work For RTEMS
Thanks for responding. I did mostly pthread and documentation work on
the GCI last year, but I've probably gotten a bit rusty. Do you have
anything that would be considered "entry level" or "intermediate"?
Documentation would be good.
~C. Kerl
On 7/24/2013 2:26 AM, Sebastian Huber wrote:
> Hello Christoper,
> in which area are you interested?  We have for example this open bug
> that leads to two test case failures:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=1879
> For RFS and FAT some research needs to be done to fix this problem and
> what the performance impact is.
> On 2013-07-24 05:15, zargy wrote:
>> Dear RTEMS team,
>> I was wondering if there was any development work that help was
>> needed with
>> RTEMS right now. I have some time free right now to work on it.
>> ~Christopher Kerl
>> rtems-devel mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-devel
