[PATCH 1/2] smp: Delete _ISR_SMP_Initialize()
Sebastian Huber
Fri Jul 26 14:41:21 UTC 2013
cpukit/score/include/rtems/score/isr.h | 8 --------
cpukit/score/src/isr.c | 4 ----
cpukit/score/src/isrsmp.c | 4 ----
3 files changed, 0 insertions(+), 16 deletions(-)
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index 0c2abe6..8d57db2 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -98,14 +98,6 @@ void _ISR_Handler_initialization ( void );
#if defined( RTEMS_SMP )
- * @brief Initialize SMP interrupt critical section support.
- * This method initializes the variables required by the SMP implementation
- * of interrupt critical section management.
-void _ISR_SMP_Initialize(void);
* @brief Enter SMP interrupt code.
* This method is used to enter the SMP interrupt section.
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index eaf6ba6..3adea71 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -76,8 +76,4 @@ void _ISR_Handler_initialization( void )
#if ( CPU_HAS_HARDWARE_INTERRUPT_STACK == TRUE )
_CPU_Install_interrupt_stack();
#endif
-#if defined(RTEMS_SMP)
- _ISR_SMP_Initialize();
-#endif
diff --git a/cpukit/score/src/isrsmp.c b/cpukit/score/src/isrsmp.c
index d97c9c3..7725c30 100644
--- a/cpukit/score/src/isrsmp.c
+++ b/cpukit/score/src/isrsmp.c
@@ -24,10 +24,6 @@
#include <rtems/score/smp.h>
ISR_Level _ISR_SMP_Disable(void)
ISR_Level level;
1.7.7
