SMP Problem on i386
Sebastian Huber
Tue Jul 30 15:51:27 UTC 2013
Hello,
if I apply the following patch
diff --git a/cpukit/score/include/rtems/bspsmp.h
b/cpukit/score/include/rtems/bspsmp.h
index ec8be9f..69cbff4 100644
--- a/cpukit/score/include/rtems/bspsmp.h
+++ b/cpukit/score/include/rtems/bspsmp.h
@@ -104,8 +104,7 @@ void bsp_smp_broadcast_interrupt(void);
* This function must not be called by the main processor. This function does
* not return to the caller.
-void rtems_smp_secondary_cpu_initialize( void )
- RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+void rtems_smp_secondary_cpu_initialize( void );
* @brief Process the incoming interprocessor request.
then the i386 SMP test cases fail on Qemu. I get a General Protection Fault
after the "iret" in _ISR_Handler.
What could be the reason for this?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
