SMP Problem on i386
Chris Johns
chrisj at rtems.org
Tue Jul 30 16:03:12 UTC 2013
Sebastian Huber wrote:
> Hello,
> if I apply the following patch
> diff --git a/cpukit/score/include/rtems/bspsmp.h
> b/cpukit/score/include/rtems/bspsmp.h
> index ec8be9f..69cbff4 100644
> --- a/cpukit/score/include/rtems/bspsmp.h
> +++ b/cpukit/score/include/rtems/bspsmp.h
> @@ -104,8 +104,7 @@ void bsp_smp_broadcast_interrupt(void);
> * This function must not be called by the main processor. This function
> does
> * not return to the caller.
> -void rtems_smp_secondary_cpu_initialize( void )
> - RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
> +void rtems_smp_secondary_cpu_initialize( void );
> * @brief Process the incoming interprocessor request.
> then the i386 SMP test cases fail on Qemu. I get a General Protection
> Fault after the "iret" in _ISR_Handler.
> What could be the reason for this?
The manual states you cannot assume registers are restored before
calling the no return function. Is there an assumption about the state
of the registers that made it just work ?
