[PATCH] Updated legacy code in ata & dec21140
Vipul Nayyar
nayyar_vipul at yahoo.com
Wed Jul 31 15:53:46 UTC 2013
c/src/libchip/ide/ata.c | 77 ++++++++++++----------------------------
c/src/libchip/network/dec21140.c | 52 ++++++++++-----------------
2 files changed, 40 insertions(+), 89 deletions(-)
diff --git a/c/src/libchip/ide/ata.c b/c/src/libchip/ide/ata.c
index 8229714..f48205d 100644
--- a/c/src/libchip/ide/ata.c
+++ b/c/src/libchip/ide/ata.c
@@ -35,6 +35,7 @@ bool ata_trace;
#if CPU_SIMPLE_VECTORED_INTERRUPTS != TRUE
#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
#define ATA_IRQ_CHAIN_MAX_CNT 4 /* support up to 4 ATA devices */
typedef struct {
rtems_irq_number name;
@@ -610,7 +611,7 @@ static rtems_isr ata_interrupt_handler(rtems_vector_number vec)
#else
-static void ata_interrupt_handler(rtems_irq_hdl_param handle)
+static void ata_interrupt_handler(void * handle)
int ata_irq_chain_index = (int) handle;
rtems_chain_node *the_node =
@@ -637,7 +638,7 @@ static void ata_interrupt_handler(rtems_irq_hdl_param handle)
-static void ata_interrupt_on(const rtems_irq_connect_data *ptr)
+static void ata_interrupt_on(void)
/* enable ATA device interrupt */
@@ -647,42 +648,6 @@ static void ata_interrupt_on(const rtems_irq_connect_data *ptr)
-static void ata_interrupt_off(const rtems_irq_connect_data *ptr)
- /* disable ATA device interrupt */
- ide_controller_write_register(0,
- IDE_REGISTER_DEVICE_CONTROL_OFFSET,
- IDE_REGISTER_DEVICE_CONTROL_nIEN
-static int ata_interrupt_isOn(const rtems_irq_connect_data *ptr)
- uint16_t byte; /* emphasize that only 8 low bits is meaningful */
- /* return int. status od ATA device */
- ide_controller_read_register(0,
- &byte
- return !(byte & IDE_REGISTER_DEVICE_CONTROL_nIEN);
-static rtems_irq_connect_data ata_irq_data =
- 0, /* filled out before use... */
- ata_interrupt_handler,/* filled out before use... */
- NULL,
- ata_interrupt_on,
- ata_interrupt_off,
- ata_interrupt_isOn
#endif
/* ata_pio_in_protocol --
@@ -1250,23 +1215,25 @@ rtems_ata_initialize(rtems_device_major_number major,
* no match found, try to use new channel entry
- if (ata_irq_chain_cnt < ATA_IRQ_CHAIN_MAX_CNT) {
- ata_irq_chain_use = ata_irq_chain_cnt++;
- ata_irq_chain[ata_irq_chain_use].name =
- IDE_Controller_Table[ctrl_minor].int_vec;
- ata_irq_data.name =
- ata_irq_data.hdl = ata_interrupt_handler;
- ata_irq_data.handle = (rtems_irq_hdl_param) ctrl_minor;
- status = ((0 == BSP_install_rtems_irq_handler(&ata_irq_data))
- ? RTEMS_INVALID_NUMBER
- : RTEMS_SUCCESSFUL);
- else {
- status = RTEMS_TOO_MANY;
+ if (ata_irq_chain_cnt < ATA_IRQ_CHAIN_MAX_CNT) {
+ ata_irq_chain_use = ata_irq_chain_cnt++;
+ ata_irq_chain[ata_irq_chain_use].name =
+ IDE_Controller_Table[ctrl_minor].int_vec;
+ status = rtems_interrupt_handler_install(
+ IDE_Controller_Table[ctrl_minor].int_vec,
+ "ATA",
+ RTEMS_INTERRUPT_UNIQUE,
+ ata_interrupt_handler,
+ (void *)ctrl_minor
+ assert(status == RTEMS_SUCCESSFUL);
+ ata_interrupt_on();
+ else {
+ status = RTEMS_TOO_MANY;
#endif
if (status != RTEMS_SUCCESSFUL)
diff --git a/c/src/libchip/network/dec21140.c b/c/src/libchip/network/dec21140.c
index 997b34c..bcf7180 100644
--- a/c/src/libchip/network/dec21140.c
+++ b/c/src/libchip/network/dec21140.c
@@ -74,6 +74,7 @@
#include <stdarg.h>
+#include <assert.h>
#include <rtems/error.h>
#include <rtems/bspIo.h>
@@ -244,7 +245,7 @@ struct dec21140_softc {
struct arpcom arpcom;
- rtems_irq_connect_data irqInfo;
+ rtems_vector_number name;
rtems_event_set ioevent;
int numRxbuffers, numTxbuffers;
@@ -340,16 +341,6 @@ static int eeget16(volatile uint32_t *ioaddr, int location)
return ( ((retval<<8)&0xff00) | ((retval>>8)&0xff) );
-static void no_op(const rtems_irq_connect_data* irq)
- return;
-static int dec21140IsOn(const rtems_irq_connect_data* irq)
- return BSP_irq_enabled_at_i8259s (irq->name);
* DEC21140 interrupt handler
@@ -378,7 +369,7 @@ dec21140Enet_interrupt_handler ( struct dec21140_softc *sc )
static rtems_isr
-dec21140Enet_interrupt_handler_entry(void)
+dec21140Enet_interrupt_handler_entry(void * arg)
int i;
@@ -399,7 +390,8 @@ dec21140Enet_interrupt_handler_entry(void)
static void
dec21140Enet_initialize_hardware (struct dec21140_softc *sc)
- int i,st;
+ int i;
+ rtems_status_code status;
volatile uint32_t *tbase;
volatile unsigned char *cp, *setup_frm, *eaddrs;
volatile unsigned char *buffer;
@@ -412,7 +404,7 @@ dec21140Enet_initialize_hardware (struct dec21140_softc *sc)
sc->arpcom.ac_enaddr[2], sc->arpcom.ac_enaddr[3],
sc->arpcom.ac_enaddr[4], sc->arpcom.ac_enaddr[5],
sc->arpcom.ac_if.if_name, sc->arpcom.ac_if.if_unit,
- sc->port, (unsigned) sc->base, sc->irqInfo.name );
+ sc->port, (unsigned) sc->base, sc->name );
#endif
tbase = sc->base;
@@ -536,22 +528,18 @@ dec21140Enet_initialize_hardware (struct dec21140_softc *sc)
sc->TxMD = rmd+1;
- sc->irqInfo.hdl = (rtems_irq_hdl)dec21140Enet_interrupt_handler_entry;
- sc->irqInfo.on = no_op;
- sc->irqInfo.off = no_op;
- sc->irqInfo.isOn = dec21140IsOn;
#ifdef DEC_DEBUG
- printk( "dec2114x: Installing IRQ %d\n", sc->irqInfo.name );
-#endif
-#ifdef BSP_SHARED_HANDLER_SUPPORT
- st = BSP_install_rtems_shared_irq_handler( &sc->irqInfo );
-#else
- st = BSP_install_rtems_irq_handler( &sc->irqInfo );
+ printk( "dec2114x: Installing IRQ %d\n", sc->name );
#endif
- if (!st)
- rtems_panic ("dec2114x : Interrupt name %d already in use\n", sc->irqInfo.name );
+ sc->name,
+ "DEC21140",
+ dec21140Enet_interrupt_handler_entry,
+ NULL
static void
@@ -668,7 +656,7 @@ sendpacket (struct ifnet *ifp, struct mbuf *m)
* Driver transmit daemon
-void
+static void
dec21140_txDaemon (void *arg)
struct dec21140_softc *sc;
@@ -735,10 +723,7 @@ dec21140_init (void *arg)
* Set up DEC21140 hardware if its not already been done
- if( !sc->irqInfo.hdl )
- dec21140Enet_initialize_hardware (sc);
+ dec21140Enet_initialize_hardware (sc);
* Enable RX and TX
@@ -1020,8 +1005,7 @@ rtems_dec21140_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
** Store the interrupt name, we'll use it later when we initialize
** the board.
- memset(&sc->irqInfo,0,sizeof(rtems_irq_connect_data));
- sc->irqInfo.name = cvalue;
+ sc->name = cvalue;
#ifdef DEC_DEBUG
1.7.11.7
