Thread Life-Cycle Changes
Fri Jul 5 15:17:28 UTC 2013
Summary?: Change thread state changes issued during thread dispatch
disable protection into delayed state changes that are processed by
the thread itself or by a kernel worker thread when protection is
disabled.
The idea seems right to me, but we should release 4.11 before we make
so many changes in score.
On Fri, Jul 5, 2013 at 7:01 AM, Sebastian Huber
> Hello,
> the current implementation to manage a thread life-cycle in RTEMS has some
> weaknesses that turn into severe problems on SMP.  It leads also to POSIX
> and
> C++ standard conformance defects in some cases.  Currently the thread
> life-cycle changes are protected by the thread dispatch disable level and
> some
> parts by the allocator mutex.  Since the thread dispatch disable level is
> actually a giant mutex on SMP this leads in combination with the allocator
> mutex to lock order reversal problems.
> One problematic path is the destruction of threads.  Here we have currently
> the
> following sequence:
> 1. Obtain the allocator mutex.
> 2. Disable thread dispatching.
> 3. Invalidate the object identifier.
> 4. Enable thread dispatching.
> 5. Call the thread delete extensions in the context of the deleting thread
> (not
> necessarily the deleted thread).  The POSIX cleanup handlers are
> called here from the POSIX delete extension.  POSIX mandates that the
> cleanup
> handler are executed in the context of the corresponding thread.  So here we
> have a POSIX violation.
> http://pubs.opengroup.org/onlinepubs/000095399/functions/xsh_chap02_09.html#tag_02_09_05_03
> 6. Remove the thread from the scheduling and watchdog resources.
> 7. Delete scheduling, floating-point, stack and extensions resources.  Now
> the
> deleted thread may execute on a freed thread stack!
> 8. Free the object.  Now the object (thread control block) is available for
> re-use, but it is still used by the thread!  Only the disabled thread
> dispatching prevents chaos.
> 9. Release the allocator mutex.  Now we have a lock order reversal (see step
> 1.
> and 2.).
> 10. Enable thread dispatching.  Here a deleted executing thread disappears.
> On SMP we have also a race-condition here.  This step looks in detail:
>   if ( _Thread_Dispatch_decrement_disable_level() == 0 )
>      * Here another processor may re-use resources of a deleted executing
>      * thread, e.g. the stack.
>     _Thread_Dispatch();
> To overcome the issues we need considerable implementation changes in Score.
> The thread life-cycle state must be explicit and independent of the thread
> dispatch disable level and allocator mutex protection.
> The thread life-cycle is determined by the following actions:
>   CREATE - A thread is created.
>   START - Starts a thread.  The thread must be dormant to get started.
>   RESTART - Restarts a thread.  The thread must not be dormant to get
>   restarted.
>   SUSPEND - Suspends a thread.
>   RESUME - Resumes a thread.
>   DELETE - Deletes a thread.
>   SET_PROTECTION - Sets the new protection state and returns the previous.
>   This action is new.
> The following thread life-cycle states are proposed.  These states are
> orthogonal to the blocking states, e.g. DORMANT, SUSPENDED etc.:
>   PROTECTED - The thread is protected from immediate restart, delete and
>   suspend actions.  Can be controlled by pthread_setcancelstate() for
> example.
>   RESTART_REQUESTED - The thread was PROTECTED and a valid restart action
> was
>   perfomed.  The new life-cycle state is determined once the PROTECTED state
> is
>   cleared.
>   SUSPEND_REQUESTED - The thread was PROTECTED and a valid suspend action
> was
> is
>   cleared.
>   DELETE_REQUESTED - The thread was PROTECTED and a valid delete action was
> is
>   cleared.
> If several requests are pending after a cleared PROTECTED state, then DELETE
> has the highest priority followed by SUSPEND and RESTART.
> The cleanup handler invocation must execute in the corresponding thread
> context.  In case a thread deletes itself, then this is trivial.  In case a
> thread is deleted by another thread, then we can restart the thread with a
> special reaper function that performs the delete procedure.  For this
> special
> case restart we must use the current stack pointer of the deleted thread
> since
> cleanup buffers may reside on the thread stack.
> Restarting threads executing on a remote processor requires further
> investigation.
> The release of vital thread resources, e.g. the thread control block and the
> thread stack must be split into two steps.  The first step places the
> resources
> on a garbage list.  In case new threads are allocated the garbage list is
> used
> to check for resources that can be released.  The resources on the garbage
> list
> provide a release function that tries to release the resource depending on
> its
> state (e.g. the corresponding thread stopped execution).
> I am happy to get some feedback about the proposed changes.
> rtems-devel mailing list
> rtems-devel at rtems.org
