[GSoC] libmm project status
Rempel, Cynthia
cynt6007 at vandals.uidaho.edu
Mon Jul 8 22:55:58 UTC 2013
Hi,
Thanks for providing the link directly to the testcases!
Could you copy the information about each test into:
mmtest1/mmtest1.doc
Simple tests that tries to install memory management entries
mmtest2/mmtest2.doc
+ Install entries with specific memory attributes (e.g read only region) :
+ Check for memory protection violations (writing to read only blocks)
+ Reading from read only blocks.
+ Write/Read to/from unmapped region (error!).
+ Write to a valid entry that was installed and then uninstalled (error!).
mmtest3/mmtest3.doc
+ Tests for libmm behavior on SMP environments.
+ Create tasks for each core and start it.
+ Check for memory consistency and page tables and memory attributes validity.
That way we can quickly identify what each test does in 5 years... Good job with the documentation :)
Cindy
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Hesham Moustafa [heshamelmatary at gmail.com]
Sent: Monday, July 08, 2013 3:39 PM
To: rtems-devel at rtems.org
Cc: Gedare Bloom
Subject: [GSoC] libmm project status
Hi all,
I have posted a new thread to my blog that contains a brief introduction to libmm and latest updates, here is the thread [1] Please take a look.
TODO: port libmm for Raspberry PI board on real hardware.
Questions :
I have created a new test case at libtests called mmtest3 [2] which simulate SMP use case on QEMU/Realview. It simply tries to invoke the same task (which calls libmm function) for each core. There is a fatal error at startup that branches to data exception handler but I am not sure why. Please take a look and tell me if I am doing something wrong with that test case.
Other test cases (mmtest1, mmtest2) run successfully on the same platform.
[1] http://heshamelmatary.blogspot.com/2013/07/gsoc-2013-libmm-for-rtems.html
[2] https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm/testsuites/libtests/mmtest3
Regards,
Hesham
