[GSoC] libmm project status
Tue Jul 9 17:00:47 UTC 2013
When we do the initial commit of libmm, we should link every BSP/CPU
to the nop stub implementation. We can probably get started on merging
that baseline soon. Hesham, if you can pull out a patch containing
just the nop implementation we can review it.
On Tue, Jul 9, 2013 at 12:53 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Tue, Jul 9, 2013 at 6:47 PM, Rempel, Cynthia
> <cynt6007 at vandals.uidaho.edu> wrote:
>> >>Is there a way to conditionally build the mmtests based on whether libmm
>> >> is being built?
>> >>My initial thought is something like an AM_CONDITIONAL
>> >> >>http://www.gnu.org/software/automake/manual/html_node/Subdirectories-with-AM_005fCONDITIONAL.html
>> >>Although another way to conditionally build the tests may be better...
>> >>Ideally if we went that route (and if feasible), if there was a
>> >> conditional being used for building libmm, we would use the same conditional
>> >> for the libmm tests...
>> >Sure, I can work on that.
>> Thanks!
>> My main concern is if a BSP doesn't have libmm built, will building all
>> the tests lead to a compiler / linker error?
>> If not, we needn't worry about building conditionally...
> There are stubs for libmm functions at a high-level APIs at
> no_memorymanagement.c file. So, every BSP/CPU that does not implement libmm
> functions can be built without error with including that file.
>> I'm mostly worried about getting these tests committed incrementally if
>> feasible (i.e. they don't break the build)...
>> Hopefully we can get your work committed over the summer and reduce the
>> number of patches at the end of the summer :)
>> I noticed there wasn't a copyright on the .doc s. Could you add
>> #  COPYRIGHT (c) 2013.
>> #  Hesham Moustafa.
>> #  The license and distribution terms for this file may be
>> #  found in the file LICENSE in this distribution or at
>> #  http://www.rtems.com/license/LICENSE.
>> To the top of
>> mmtest1/mmtest1.doc
>> mmtest2/mmtest2.doc
>> mmtest3/mmtest3.doc
>> Thanks!
>> Cindy
>> ________________________________________
>> From: rtems-devel-bounces at rtems.org<mailto:rtems-devel-bounces at rtems.org>
>> [rtems-devel-bounces at rtems.org<mailto:rtems-devel-bounces at rtems.org>] on
>> behalf of Rempel, Cynthia
>> [cynt6007 at vandals.uidaho.edu<mailto:cynt6007 at vandals.uidaho.edu>]
>> Sent: Monday, July 08, 2013 3:55 PM
>> To: Hesham Moustafa; rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
>> Cc: Gedare Bloom
>> Subject: RE: [GSoC] libmm project status
>> Hi,
>> Thanks for providing the link directly to the testcases!
>> Could you copy the information about each test into:
>> mmtest1/mmtest1.doc
>> Simple tests that tries to install memory management entries
>> mmtest2/mmtest2.doc
>> + Install entries with specific memory attributes (e.g read only region) :
>> + Check for memory protection violations (writing to read only blocks)
>> + Reading from read only blocks.
>> + Write/Read to/from unmapped region (error!).
>> + Write to a valid entry that was installed and then uninstalled (error!).
>> mmtest3/mmtest3.doc
>> + Tests for libmm behavior on SMP environments.
>> + Create tasks for each core and start it.
>> + Check for memory consistency and page tables and memory attributes
>> validity.
>> That way we can quickly identify what each test does in 5 years... Good
>> job with the documentation :)
>> Cindy
>> behalf of Hesham Moustafa
>> [heshamelmatary at gmail.com<mailto:heshamelmatary at gmail.com>]
>> Sent: Monday, July 08, 2013 3:39 PM
>> To: rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
>> Cc: Gedare Bloom
>> Subject: [GSoC] libmm project status
>> Hi all,
>> I have posted a new thread to my blog that contains a brief introduction
>> to libmm and latest updates, here is the thread [1] Please take a look.
>> TODO: port libmm for Raspberry PI board on real hardware.
>> Questions :
>> I have created a new test case at libtests called mmtest3 [2] which
>> simulate SMP use case on QEMU/Realview. It simply tries to invoke the same
>> task (which calls libmm function) for each core. There is a fatal error at
>> startup that branches to data exception handler but I am not sure why.
>> Please take a look and tell me if I am doing something wrong with that test
>> case.
>> Other test cases (mmtest1, mmtest2) run successfully on the same platform.
>> [1]
>> http://heshamelmatary.blogspot.com/2013/07/gsoc-2013-libmm-for-rtems.html
>> [2]
>> https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm/testsuites/libtests/mmtest3
>> Regards,
>> Hesham
>> rtems-devel mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-devel
