[GSoC] libmm project status
Hesham Moustafa
heshamelmatary at gmail.com
Tue Jul 9 17:09:01 UTC 2013
On Tue, Jul 9, 2013 at 7:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
> When we do the initial commit of libmm, we should link every BSP/CPU
> to the nop stub implementation. We can probably get started on merging
> that baseline soon. Hesham, if you can pull out a patch containing
> just the nop implementation we can review it.
> A patch To include the stubs and high-level headers for every BSP and
changes to all Makefile.am only ?
> On Tue, Jul 9, 2013 at 12:53 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
> > On Tue, Jul 9, 2013 at 6:47 PM, Rempel, Cynthia
> > <cynt6007 at vandals.uidaho.edu> wrote:
> >> >>Is there a way to conditionally build the mmtests based on whether
> libmm
> >> >> is being built?
> >> >>My initial thought is something like an AM_CONDITIONAL
> http://www.gnu.org/software/automake/manual/html_node/Subdirectories-with-AM_005fCONDITIONAL.html
> >> >>Although another way to conditionally build the tests may be better...
> >> >>Ideally if we went that route (and if feasible), if there was a
> >> >> conditional being used for building libmm, we would use the same
> conditional
> >> >> for the libmm tests...
> >> >Sure, I can work on that.
> >> Thanks!
> >> My main concern is if a BSP doesn't have libmm built, will building all
> >> the tests lead to a compiler / linker error?
> >> If not, we needn't worry about building conditionally...
> > There are stubs for libmm functions at a high-level APIs at
> > no_memorymanagement.c file. So, every BSP/CPU that does not implement
> libmm
> > functions can be built without error with including that file.
> >> I'm mostly worried about getting these tests committed incrementally if
> >> feasible (i.e. they don't break the build)...
> >> Hopefully we can get your work committed over the summer and reduce the
> >> number of patches at the end of the summer :)
> >> I noticed there wasn't a copyright on the .doc s. Could you add
> >> # COPYRIGHT (c) 2013.
> >> # Hesham Moustafa.
> >> # The license and distribution terms for this file may be
> >> # found in the file LICENSE in this distribution or at
> >> # http://www.rtems.com/license/LICENSE.
> >> To the top of
> >> mmtest1/mmtest1.doc
> >> mmtest2/mmtest2.doc
> >> mmtest3/mmtest3.doc
> >> Thanks!
> >> Cindy
> >> ________________________________________
> >> From: rtems-devel-bounces at rtems.org<mailto:
> rtems-devel-bounces at rtems.org>
> >> [rtems-devel-bounces at rtems.org<mailto:rtems-devel-bounces at rtems.org>]
> on
> >> behalf of Rempel, Cynthia
> >> [cynt6007 at vandals.uidaho.edu<mailto:cynt6007 at vandals.uidaho.edu>]
> >> Sent: Monday, July 08, 2013 3:55 PM
> >> To: Hesham Moustafa; rtems-devel at rtems.org<mailto:rtems-devel at rtems.org
> >> Cc: Gedare Bloom
> >> Subject: RE: [GSoC] libmm project status
> >> Hi,
> >> Thanks for providing the link directly to the testcases!
> >> Could you copy the information about each test into:
> >> mmtest1/mmtest1.doc
> >> Simple tests that tries to install memory management entries
> >> mmtest2/mmtest2.doc
> >> + Install entries with specific memory attributes (e.g read only
> region) :
> >> + Check for memory protection violations (writing to read only blocks)
> >> + Reading from read only blocks.
> >> + Write/Read to/from unmapped region (error!).
> >> + Write to a valid entry that was installed and then uninstalled
> (error!).
> >> mmtest3/mmtest3.doc
> >> + Tests for libmm behavior on SMP environments.
> >> + Create tasks for each core and start it.
> >> + Check for memory consistency and page tables and memory attributes
> >> validity.
> >> That way we can quickly identify what each test does in 5 years... Good
> >> job with the documentation :)
> >> Cindy
> on
> >> behalf of Hesham Moustafa
> >> [heshamelmatary at gmail.com<mailto:heshamelmatary at gmail.com>]
> >> Sent: Monday, July 08, 2013 3:39 PM
> >> To: rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
> >> Cc: Gedare Bloom
> >> Subject: [GSoC] libmm project status
> >> Hi all,
> >> I have posted a new thread to my blog that contains a brief introduction
> >> to libmm and latest updates, here is the thread [1] Please take a look.
> >> TODO: port libmm for Raspberry PI board on real hardware.
> >> Questions :
> >> I have created a new test case at libtests called mmtest3 [2] which
> >> simulate SMP use case on QEMU/Realview. It simply tries to invoke the
> same
> >> task (which calls libmm function) for each core. There is a fatal error
> at
> >> startup that branches to data exception handler but I am not sure why.
> >> Please take a look and tell me if I am doing something wrong with that
> test
> >> case.
> >> Other test cases (mmtest1, mmtest2) run successfully on the same
> platform.
> >> [1]
> http://heshamelmatary.blogspot.com/2013/07/gsoc-2013-libmm-for-rtems.html
> >> [2]
> https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm/testsuites/libtests/mmtest3
> >> Regards,
> >> Hesham
> >> _______________________________________________
> >> rtems-devel mailing list
> >> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130709/0e760068/attachment-0001.html>
