[PATCH] Updated Legacy code in arm gba
Fri Jul 12 12:06:07 UTC 2013
Thanks for the patch:
http://git.rtems.org/rtems/commit/?id=9b6add418c0fefba50f7360453d4ca93a1379968
On 07/12/2013 01:34 PM, Vipul Nayyar wrote:
>   #define Clock_driver_support_install_isr( _new, _old )  \
>     do {                                                  \
> -    BSP_install_rtems_irq_handler(&clock_isr_data);     \
> +    rtems_status_code status = RTEMS_SUCCESSFUL;        \
> +    status = rtems_interrupt_handler_install(           \
> +        BSP_IRQ_TIMER3,                                 \
> +        "Clock",                                        \
> +        RTEMS_INTERRUPT_UNIQUE,                         \
> +        Clock_isr,                                      \
> +        NULL                                            \
> +    assert(status == RTEMS_SUCCESSFUL);                 \
>       _old = NULL;                                        \
>     } while(0)
If you can assign a value before you call a global function, then do it.  This
helps to avoid the saving of state around function calls.
So in this example it is better to move the "_old = NULL;" before the
rtems_interrupt_handler_install().  It makes no difference here in this special
case, but you should keep this in mind.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
