[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar
nayyar_vipul at yahoo.com
Fri Jul 12 12:27:33 UTC 2013
Hello,
Frankly speaking, I agree & tend to disagree at the same time.
* I agree that cs8900_isr() should be a static function, as it should not be accessed outside this file.
* The declarations for global functions should not be present in source file, because their prototypes should be present in a header file.
I don't understand, why cs8900_isr() cannot be made to pass cs8900_device *cs like I did in my patch. From where is this function is called ?
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Friday, 12 July 2013 5:40 PM
Subject: Re: [PATCH] Updated Legacy code in arm rtl22xx
On 07/12/2013 02:01 PM, Vipul Nayyar wrote:
> You want this : (rtems_interrupt_handler)cs8900_isr ?
No, I want this
static void cs8900_isr(void *arg)
cs8900_device *cs = arg;
Please remember that declarations of global functions in a source file are not
acceptable.
Do you know why this is a problem?
> Plus, Do I need to put 0 instead of NULL ? I don't know right now if I'm aware
> of the answer or I'm just overlooking it .
How does the interrupt handler function cs8900_isr() get its argument value?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130712/c81882b9/attachment-0001.html>
