[PATCH 1/4] Add libmm score changes
Hesham Moustafa
heshamelmatary at gmail.com
Thu Jul 18 03:23:34 UTC 2013
On Mon, Jul 15, 2013 at 4:18 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Overall this looks OK from what I have seen before. I have a few
> comments about how we might want to consider improving the interface
> though before we start to commit code.
> On Sat, Jul 13, 2013 at 7:05 PM, Hesham AL-Matary
> <heshamelmatary at gmail.com> wrote:
> > From: Hesham ALmatary <heshamelmatary at gmail.com>
> > cpukit/score/Makefile.am | 2 +
> > cpukit/score/include/rtems/score/mm.h | 67 ++++++++++++++++++++++++++++
> > cpukit/score/inline/rtems/score/mm.inl | 80
> > cpukit/score/preinstall.am | 8 ++++
> > 4 files changed, 157 insertions(+)
> > create mode 100644 cpukit/score/include/rtems/score/mm.h
> > create mode 100644 cpukit/score/inline/rtems/score/mm.inl
> > diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> > index 3f6e686..58a865b 100644
> > --- a/cpukit/score/Makefile.am
> > +++ b/cpukit/score/Makefile.am
> > @@ -30,6 +30,7 @@ include_rtems_score_HEADERS +=
> include/rtems/score/protectedheap.h
> > include_rtems_score_HEADERS += include/rtems/score/interr.h
> > include_rtems_score_HEADERS += include/rtems/score/isr.h
> > include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
> > +include_rtems_score_HEADERS += include/rtems/score/mm.h
> > include_rtems_score_HEADERS += include/rtems/score/object.h
> > include_rtems_score_HEADERS += include/rtems/score/percpu.h
> > include_rtems_score_HEADERS += include/rtems/score/priority.h
> > @@ -90,6 +91,7 @@ include_rtems_score_HEADERS +=
> inline/rtems/score/coremutex.inl
> > include_rtems_score_HEADERS += inline/rtems/score/coresem.inl
> > include_rtems_score_HEADERS += inline/rtems/score/heap.inl
> > include_rtems_score_HEADERS += inline/rtems/score/isr.inl
> > +include_rtems_score_HEADERS += inline/rtems/score/mm.inl
> > include_rtems_score_HEADERS += inline/rtems/score/object.inl
> > include_rtems_score_HEADERS += inline/rtems/score/priority.inl
> > include_rtems_score_HEADERS += inline/rtems/score/prioritybitmap.inl
> > diff --git a/cpukit/score/include/rtems/score/mm.h
> b/cpukit/score/include/rtems/score/mm.h
> > new file mode 100644
> > index 0000000..6163be6
> > --- /dev/null
> > +++ b/cpukit/score/include/rtems/score/mm.h
> > @@ -0,0 +1,67 @@
> > + * @file
> > + * @brief Manages use of MPU/MMU units to provide memory management.
> > + * Copyright (c) 2013 Hesham Al-Matary.
> > + * Copyright (c) 2013 Gedare Bloom.
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.com/license/LICENSE.
> > +#ifndef _RTEMS_SCORE_MM_H
> > +#define _RTEMS_SCORE_MM_H
> > +/* @defgroup SuperCoreMM Memory Management Support
> > + * @ingroup Score
> > +#include <inttypes.h>
> > +#ifdef RTEMS_SMP
> > +#include <rtems/score/smplock.h>
> > +#endif
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif
> > + * @brief _Memory_management_Region Flags defs
> > +#define RTEMS_MM_REGION_PROTECTION_READ_ONLY 0x1
> This should maybe be "READ" instead of "READ_ONLY".
> > +#define RTEMS_MM_REGION_PROTECTION_WRITE 0x2
> > +//#define RTEMS_MM_REGION_PROTECTION_EXEC 0x4
> > + * @brief A managed _Memory_management_Region.
> > +typedef struct {
> > + char *name;
> > + uintptr_t base;
> > + size_t size;
> > + bool installed;
> > + /* points to structure defining the BSP specific MM entry */
> > + void *bsp_mme;
> > +} Memory_management_Entry;
> I wonder if we need "installed" and "bsp_mme".
> The "installed" field can be used at high-level layers (and I use it at
low-level arm libmm) to check if the entry to be installed is already
installed or not. I think mme is important too at high-level layer if we
want to keep track of high-level mme and keep them in a data structures
like a free/busy list or similar data structure.
> > +#ifdef RTEMS_SMP
> > +SMP_lock_Control mm_lock;
> > +#endif
> > +#ifndef __RTEMS_APPLICATION__
> > +#include <rtems/score/mm.inl>
> > +#endif
> > +#ifdef __cplusplus
> > +#endif
> > +#endif
> > diff --git a/cpukit/score/inline/rtems/score/mm.inl
> b/cpukit/score/inline/rtems/score/mm.inl
> > index 0000000..07b1dd7
> > --- /dev/null
> > +++ b/cpukit/score/inline/rtems/score/mm.inl
> > @@ -0,0 +1,80 @@
> > + * @file
> > + * @brief Inlined Routines from the Memory Management Manager
> > + * Copyright (c) 2013 Hesham AL-Matary
> > +# error "Never use <rtems/score/mm.inl> directly; include
> <rtems/score/mm.h> instead."
> > +#endif
> > +#ifndef _RTEMS_SCORE_MM_INL
> > +#define _RTEMS_SCORE_MM_INL
> > + * @addtogroup SuperCoreMM
> > + * @brief Calls _CPU_Memory_management_Initialize.
> > +RTEMS_INLINE_ROUTINE void _Memory_management_Initialize( void )
> > +#ifdef RTEMS_SMP
> > + _SMP_lock_Initialize( &mm_lock );
> > +#endif
> > + _CPU_Memory_management_Initialize();
> > + * @brief Calls _CPU_Memory_management_Install_entry.
> > +RTEMS_INLINE_ROUTINE void _Memory_management_Install_entry(
> > + Memory_management_Entry *mme,
> > + uint32_t attr
> We should consider whether these functions should instead take
> arguments directly for the start and size of memory regions. At what
> layer do we want to "strip off" the other metadata like name?
Yes, I will convert the prototypes for this function to take base, size and
attributes directly.
I think the stripping off process it should be at middle layer if we
intend to high-level entries into a data structure.
> > +#ifdef RTEMS_SMP
> > + _SMP_lock_Acquire( &mm_lock );
> > +#endif
> > + _CPU_Memory_management_Install_entry(mme, attr);
> > +#ifdef RTEMS_SMP
> > + _SMP_lock_Release( &mm_lock );
> > +#endif
> > + * @brief Calls _CPU_Memory_management_Uninstall_entry.
> > +RTEMS_INLINE_ROUTINE void _Memory_management_Uninstall_entry(
> > +#ifdef RTEMS_SMP
> > +#endif
> > + _CPU_Memory_management_Uninstall_entry(mme);
> > +#ifdef RTEMS_SMP
> > +#endif
> > +#endif
> > diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> > index dc84b21..100f090 100644
> > --- a/cpukit/score/preinstall.am
> > +++ b/cpukit/score/preinstall.am
> > @@ -103,6 +103,10 @@ $(PROJECT_INCLUDE)/rtems/score/isrlevel.h:
> include/rtems/score/isrlevel.h $(PROJ
> > $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
> > PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
> > +$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h
> $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
> > +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
> > $(PROJECT_INCLUDE)/rtems/score/object.h: include/rtems/score/object.h
> > $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.h
> > PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.h
> > @@ -298,6 +302,10 @@ $(PROJECT_INCLUDE)/rtems/score/isr.inl:
> inline/rtems/score/isr.inl $(PROJECT_INC
> > $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isr.inl
> > PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isr.inl
> > +$(PROJECT_INCLUDE)/rtems/score/mm.inl: inline/rtems/score/mm.inl
> > + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.inl
> > +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.inl
> > $(PROJECT_INCLUDE)/rtems/score/object.inl:
> inline/rtems/score/object.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.inl
> > PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.inl
> > 1.8.3.1
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130718/0edcef8e/attachment-0001.html>
