[PATCH 09/25] score: Move ISR level content to single file
Thu Jul 18 14:25:57 UTC 2013
 cpukit/score/include/rtems/score/isr.h      |  184 +--------------------------
 cpukit/score/include/rtems/score/isrlevel.h |  185 +++++++++++++++++++++++++++
 cpukit/score/include/rtems/score/smplock.h  |    2 +-
 3 files changed, 188 insertions(+), 183 deletions(-)
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index 893f6c0..cb9c6ec 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -96,65 +96,7 @@ SCORE_EXTERN ISR_Handler_entry *_ISR_Vector_table;
 void _ISR_Handler_initialization ( void );
- *  @brief Disable interrupts on this core.
- *  This routine disables all interrupts so that a critical section
- *  of code can be executing without being interrupted.
- *  @retval The argument @a _level will contain the previous interrupt
- *          mask level.
-#define _ISR_Disable_on_this_core( _level ) \
-  do { \
-    _CPU_ISR_Disable( _level ); \
-    RTEMS_COMPILER_MEMORY_BARRIER(); \
-  } while (0)
- *  @brief Enable interrupts on this core.
- *  This routine enables interrupts to the previous interrupt mask
- *  LEVEL.  It is used at the end of a critical section of code to
- *  enable interrupts so they can be processed again.
- *  @param[in] _level contains the interrupt level mask level
- *             previously returned by @ref _ISR_Disable_on_this_core.
-#define _ISR_Enable_on_this_core( _level ) \
-  do { \
-    _CPU_ISR_Enable( _level ); \
-  } while (0)
- *  @brief Temporarily enable interrupts on this core.
- *  This routine temporarily enables interrupts to the previous
- *  interrupt mask level and then disables all interrupts so that
- *  the caller can continue into the second part of a critical
- *  section.
- *  This routine is used to temporarily enable interrupts
- *  during a long critical section.  It is used in long sections of
- *  critical code when a point is reached at which interrupts can
- *  be temporarily enabled.  Deciding where to flash interrupts
- *  in a long critical section is often difficult and the point
- *  must be selected with care to ensure that the critical section
- *  properly protects itself.
-#define _ISR_Flash_on_this_core( _level ) \
-  do { \
-    _CPU_ISR_Flash( _level ); \
-  } while (0)
-#if defined(RTEMS_SMP)
+#if defined( RTEMS_SMP )
  *  @brief Initialize SMP interrupt critical section support.
@@ -164,38 +106,6 @@ void _ISR_Handler_initialization ( void );
 void _ISR_SMP_Initialize(void);
- *  @brief Enter interrupt critical section on SMP system.
- *  This method is used to enter an interrupt critical section that
- *  is honored across all cores in an SMP system.
- *  @retval This method returns the previous interrupt mask level.
-ISR_Level _ISR_SMP_Disable(void);
- *  @brief Exit interrupt critical section on SMP system.
- *  This method is used to exit an interrupt critical section that
- *  @param[in] level contains the interrupt level mask level
- *             previously returned by @ref _ISR_SMP_Disable.
-void _ISR_SMP_Enable(ISR_Level level);
- *  @brief Temporarily exit interrupt critical section on SMP system.
- *  This method is used to temporarily exit an interrupt critical section
- *  that is honored across all cores in an SMP system.
-void _ISR_SMP_Flash(ISR_Level level);
  *  @brief Enter SMP interrupt code.
  *  This method is used to enter the SMP interrupt section.
@@ -214,68 +124,7 @@ int _ISR_SMP_Enter(void);
 int _ISR_SMP_Exit(void);
-#endif
- *  @brief Enter interrupt disable critical section.
- *  This routine enters an interrupt disable critical section.  When
- *  in an SMP configuration, this involves obtaining a spinlock to ensure
- *  that only one core is inside an interrupt disable critical section.
- *  When on a single core system, this only involves disabling local
- *  CPU interrupts.
- *          mask level.
-  #define _ISR_Disable( _level ) \
-    _level = _ISR_SMP_Disable();
-#else
-    _ISR_Disable_on_this_core( _level );
-#endif
- *  @brief Exits interrupt disable critical section.
- *  This routine exits an interrupt disable critical section.  When
- *  in an SMP configuration, this involves releasing a spinlock.
- *  CPU interrupts.
- *          mask level.
-  #define _ISR_Enable( _level ) \
-    _ISR_SMP_Enable( _level );
-#else
-    _ISR_Enable_on_this_core( _level );
-#endif
- *  @brief Temporarily exit interrupt disable critical section.
- *          mask level.
-  #define _ISR_Flash( _level ) \
-    _ISR_SMP_Flash( _level );
-#else
-    _ISR_Flash_on_this_core( _level );
-#endif
+#endif /* defined( RTEMS_SMP ) */
  *  @brief Install interrupt handler vector.
@@ -298,35 +147,6 @@ int _ISR_SMP_Exit(void);
   _CPU_ISR_install_vector( _vector, _new_handler, _old_handler )
- *  @brief Return current interrupt level.
- *  This routine returns the current interrupt level.
- *  LM32 Specific Information:
- *  XXX document implementation including references if appropriate
- *  @retval This method returns the current level.
-#define _ISR_Get_level() \
-        _CPU_ISR_Get_level()
- *  @brief Set current interrupt level.
- *  This routine sets the current interrupt level to that specified
- *  by @a _new_level.  The new interrupt level is effective when the
- *  routine exits.
- *  @param[in] _new_level contains the desired interrupt level.
-#define _ISR_Set_level( _new_level ) \
-  do { \
-    _CPU_ISR_Set_level( _new_level ); \
-  } while (0)
  *  @brief ISR interrupt dispatcher.
  *  This routine is the interrupt dispatcher.  ALL interrupts
diff --git a/cpukit/score/include/rtems/score/isrlevel.h b/cpukit/score/include/rtems/score/isrlevel.h
index e3146e4..32263db 100644
--- a/cpukit/score/include/rtems/score/isrlevel.h
+++ b/cpukit/score/include/rtems/score/isrlevel.h
@@ -19,6 +19,8 @@
 #ifndef _RTEMS_SCORE_ISR_LEVEL_h
 #define _RTEMS_SCORE_ISR_LEVEL_h
+#include <rtems/score/cpu.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -38,6 +40,189 @@ extern "C" {
 typedef uint32_t   ISR_Level;
+ *  @brief Disable interrupts on this core.
+ *  This routine disables all interrupts so that a critical section
+ *  of code can be executing without being interrupted.
+ *  @retval The argument @a _level will contain the previous interrupt
+ *          mask level.
+#define _ISR_Disable_on_this_core( _level ) \
+  do { \
+    _CPU_ISR_Disable( _level ); \
+    RTEMS_COMPILER_MEMORY_BARRIER(); \
+  } while (0)
+ *  @brief Enable interrupts on this core.
+ *  This routine enables interrupts to the previous interrupt mask
+ *  LEVEL.  It is used at the end of a critical section of code to
+ *  enable interrupts so they can be processed again.
+ *  @param[in] _level contains the interrupt level mask level
+ *             previously returned by @ref _ISR_Disable_on_this_core.
+#define _ISR_Enable_on_this_core( _level ) \
+  do { \
+    _CPU_ISR_Enable( _level ); \
+  } while (0)
+ *  @brief Temporarily enable interrupts on this core.
+ *  This routine temporarily enables interrupts to the previous
+ *  interrupt mask level and then disables all interrupts so that
+ *  the caller can continue into the second part of a critical
+ *  section.
+ *  This routine is used to temporarily enable interrupts
+ *  during a long critical section.  It is used in long sections of
+ *  critical code when a point is reached at which interrupts can
+ *  be temporarily enabled.  Deciding where to flash interrupts
+ *  in a long critical section is often difficult and the point
+ *  must be selected with care to ensure that the critical section
+ *  properly protects itself.
+#define _ISR_Flash_on_this_core( _level ) \
+  do { \
+    _CPU_ISR_Flash( _level ); \
+  } while (0)
+ *  @brief Enter interrupt critical section on SMP system.
+ *  This method is used to enter an interrupt critical section that
+ *  is honored across all cores in an SMP system.
+ *  @retval This method returns the previous interrupt mask level.
+ISR_Level _ISR_SMP_Disable(void);
+ *  @brief Exit interrupt critical section on SMP system.
+ *  This method is used to exit an interrupt critical section that
+ *  @param[in] level contains the interrupt level mask level
+ *             previously returned by @ref _ISR_SMP_Disable.
+void _ISR_SMP_Enable(ISR_Level level);
+ *  @brief Temporarily exit interrupt critical section on SMP system.
+ *  This method is used to temporarily exit an interrupt critical section
+ *  that is honored across all cores in an SMP system.
+void _ISR_SMP_Flash(ISR_Level level);
+ *  @brief Enter interrupt disable critical section.
+ *  This routine enters an interrupt disable critical section.  When
+ *  in an SMP configuration, this involves obtaining a spinlock to ensure
+ *  that only one core is inside an interrupt disable critical section.
+ *  When on a single core system, this only involves disabling local
+ *  CPU interrupts.
+ *          mask level.
+  #define _ISR_Disable( _level ) \
+    _level = _ISR_SMP_Disable();
+#else
+    _ISR_Disable_on_this_core( _level );
+#endif
+ *  @brief Exits interrupt disable critical section.
+ *  This routine exits an interrupt disable critical section.  When
+ *  in an SMP configuration, this involves releasing a spinlock.
+ *  CPU interrupts.
+ *          mask level.
+  #define _ISR_Enable( _level ) \
+    _ISR_SMP_Enable( _level );
+#else
+    _ISR_Enable_on_this_core( _level );
+#endif
+ *  @brief Temporarily exit interrupt disable critical section.
+ *          mask level.
+  #define _ISR_Flash( _level ) \
+    _ISR_SMP_Flash( _level );
+#else
+    _ISR_Flash_on_this_core( _level );
+#endif
+ *  @brief Return current interrupt level.
+ *  This routine returns the current interrupt level.
+ *  LM32 Specific Information:
+ *  XXX document implementation including references if appropriate
+ *  @retval This method returns the current level.
+#define _ISR_Get_level() \
+        _CPU_ISR_Get_level()
+ *  @brief Set current interrupt level.
+ *  This routine sets the current interrupt level to that specified
+ *  by @a _new_level.  The new interrupt level is effective when the
+ *  routine exits.
+ *  @param[in] _new_level contains the desired interrupt level.
+#define _ISR_Set_level( _new_level ) \
+  do { \
+    _CPU_ISR_Set_level( _new_level ); \
+  } while (0)
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
index 2f12fdd..6b77114 100644
--- a/cpukit/score/include/rtems/score/smplock.h
+++ b/cpukit/score/include/rtems/score/smplock.h
@@ -25,7 +25,7 @@
 #include <rtems/score/cpusmplock.h>
-#include <rtems/score/isr.h>
+#include <rtems/score/isrlevel.h>
 #ifdef __cplusplus
 extern "C" {
1.7.7
