[PATCH 10/25] score: Move ISR catch support functions
Sebastian Huber
Thu Jul 18 14:25:58 UTC 2013
Delete now unused file <rtems/score/isr.inl>.
cpukit/rtems/src/intrcatch.c | 24 ++++++++++++
cpukit/score/Makefile.am | 1 -
cpukit/score/include/rtems/score/isr.h | 2 -
cpukit/score/inline/rtems/score/isr.inl | 60 -------------------------------
cpukit/score/preinstall.am | 4 --
5 files changed, 24 insertions(+), 67 deletions(-)
delete mode 100644 cpukit/score/inline/rtems/score/isr.inl
diff --git a/cpukit/rtems/src/intrcatch.c b/cpukit/rtems/src/intrcatch.c
index 0326a18..e5c7176 100644
--- a/cpukit/rtems/src/intrcatch.c
+++ b/cpukit/rtems/src/intrcatch.c
@@ -25,6 +25,30 @@
#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
+ * This function returns true if the vector is a valid vector number
+ * for this processor and false otherwise.
+RTEMS_INLINE_ROUTINE bool _ISR_Is_vector_number_valid (
+ uint32_t vector
+ return ( vector <= CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER );
+ * This function returns true if handler is the entry point of a valid
+ * use interrupt service routine and false otherwise.
+RTEMS_INLINE_ROUTINE bool _ISR_Is_valid_user_handler (
+ void *handler
+ return (handler != NULL);
rtems_status_code rtems_interrupt_catch(
rtems_isr_entry new_isr_handler,
rtems_vector_number vector,
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 8722c6e..09a87d8 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -90,7 +90,6 @@ include_rtems_score_HEADERS += inline/rtems/score/corebarrier.inl
include_rtems_score_HEADERS += inline/rtems/score/coremsg.inl
include_rtems_score_HEADERS += inline/rtems/score/coresem.inl
include_rtems_score_HEADERS += inline/rtems/score/heap.inl
-include_rtems_score_HEADERS += inline/rtems/score/isr.inl
include_rtems_score_HEADERS += inline/rtems/score/object.inl
include_rtems_score_HEADERS += inline/rtems/score/priority.inl
include_rtems_score_HEADERS += inline/rtems/score/prioritybitmap.inl
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index cb9c6ec..d174912 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -193,8 +193,6 @@ void _ISR_Dispatch( void );
(_ISR_Nest_level != 0)
#endif
-#include <rtems/score/isr.inl>
#ifdef __cplusplus
#endif
diff --git a/cpukit/score/inline/rtems/score/isr.inl b/cpukit/score/inline/rtems/score/isr.inl
deleted file mode 100644
index c46c585..0000000
--- a/cpukit/score/inline/rtems/score/isr.inl
+++ /dev/null
@@ -1,60 +0,0 @@
- * @file
- * @brief Inlined Routines in the Interrupt Handler
- * This include file contains the static implementation of all
- * inlined routines in the Interrupt Handler.
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#ifndef _RTEMS_SCORE_ISR_H
-# error "Never use <rtems/score/isr.inl> directly; include <rtems/score/isr.h> instead."
-#endif
-#ifndef _RTEMS_SCORE_ISR_INL
-#define _RTEMS_SCORE_ISR_INL
- * @addtogroup ScoreISR
-#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
- * This function returns true if the vector is a valid vector number
- * for this processor and false otherwise.
-RTEMS_INLINE_ROUTINE bool _ISR_Is_vector_number_valid (
- uint32_t vector
- return ( vector <= CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER );
- * This function returns true if handler is the entry point of a valid
- * use interrupt service routine and false otherwise.
-RTEMS_INLINE_ROUTINE bool _ISR_Is_valid_user_handler (
- void *handler
- return (handler != NULL);
-#endif
-#endif
-/* end of include file */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 5d880f1..0bbb879 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -291,10 +291,6 @@ $(PROJECT_INCLUDE)/rtems/score/heap.inl: inline/rtems/score/heap.inl $(PROJECT_I
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/heap.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/heap.inl
-$(PROJECT_INCLUDE)/rtems/score/isr.inl: inline/rtems/score/isr.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isr.inl
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isr.inl
$(PROJECT_INCLUDE)/rtems/score/object.inl: inline/rtems/score/object.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.inl
1.7.7
