[PATCH 11/25] score: Add and use _ISR_Get_nest_level()
Sebastian Huber
Thu Jul 18 14:25:59 UTC 2013
cpukit/score/include/rtems/score/isr.h | 32 ++++++++++++++++++++++++++++++--
1 files changed, 30 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index d174912..0c2abe6 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -21,8 +21,8 @@
#ifndef _RTEMS_SCORE_ISR_H
#define _RTEMS_SCORE_ISR_H
-#include <rtems/score/cpu.h>
#include <rtems/score/isrlevel.h>
+#include <rtems/score/percpu.h>
* @defgroup ScoreISR ISR Handler
@@ -178,6 +178,34 @@ void _ISR_Handler( void );
void _ISR_Dispatch( void );
+ * @brief Returns the current ISR nest level
+ * This function can be called in any context. On SMP configurations
+ * interrupts are disabled to ensure that the processor index is used
+ * consistently.
+ * @return The current ISR nest level.
+RTEMS_INLINE_ROUTINE uint32_t _ISR_Get_nest_level( void )
+ uint32_t isr_nest_level;
+ #if defined( RTEMS_SMP )
+ ISR_Level level;
+ _ISR_Disable( level );
+ #endif
+ isr_nest_level = _ISR_Nest_level;
+ _ISR_Enable( level );
+ #endif
+ return isr_nest_level;
* @brief Checks if an ISR in progress.
* This function returns true if the processor is currently servicing
@@ -190,7 +218,7 @@ void _ISR_Dispatch( void );
bool _ISR_Is_in_progress( void );
#else
#define _ISR_Is_in_progress() \
- (_ISR_Nest_level != 0)
+ (_ISR_Get_nest_level() != 0)
#endif
#ifdef __cplusplus
1.7.7
