[PATCH] clean up all the spatomic test cases
Rempel, Cynthia
cynt6007 at vandals.uidaho.edu
Sat Jul 20 20:14:29 UTC 2013
>________________________________________
>From: Deng Hengyi [wei.a.yang at gmail.com]
>Sent: Friday, July 19, 2013 8:22 AM
>To: Rempel, Cynthia
>Cc: rtems-devel at rtems.org
>Subject: Re: [PATCH] clean up all the spatomic test cases
>在 2013-7-19,上午12:16,"Rempel, Cynthia" <cynt6007 at vandals.uidaho.edu> 写道:
>> Hi Wei Yang,
>> I noticed some emails in the archive discussing fixes to the tests, such as http://www.rtems.org/pipermail/rtems-devel/2013-July/003562.html ...
>> Do we really want to delete them, instead of applying the fix?
>After discussion with Sebastian, Those test cases will not be useful, we will design new test case for new atomic implementation.
So, to clarify, making the changes in http://www.rtems.org/pipermail/rtems-devel/2013-July/003562.html will not make the tests useful, and so we should delete the tests... and as the tests are testing a depracted API we should delete them...
