[PATCH] clean up all the spatomic test cases
Deng Hengyi wei.a.yang at gmail.com
Sun Jul 21 01:55:20 UTC 2013
在 2013-7-21,上午4:14,"Rempel, Cynthia" <cynt6007 at vandals.uidaho.edu> 写道:
>> ________________________________________
>> From: Deng Hengyi [wei.a.yang at gmail.com]
>> Sent: Friday, July 19, 2013 8:22 AM
>> To: Rempel, Cynthia
>> Cc: rtems-devel at rtems.org
>> Subject: Re: [PATCH] clean up all the spatomic test cases
>> 在 2013-7-19,上午12:16,"Rempel, Cynthia" <cynt6007 at vandals.uidaho.edu> 写道:
>>> Hi Wei Yang,
>>> I noticed some emails in the archive discussing fixes to the tests, such as http://www.rtems.org/pipermail/rtems-devel/2013-July/003562.html ...
>>> Do we really want to delete them, instead of applying the fix?
>> After discussion with Sebastian,  Those test cases will not be useful, we will design new test case for new atomic implementation.
> So, to clarify, making the changes in http://www.rtems.org/pipermail/rtems-devel/2013-July/003562.html will not make the tests useful, and so we should delete the tests... and as the tests are testing a depracted API we should delete them...
Yeah, actually the main role of  those test case is to test whether atomic ops complier and link works in the first introduction. It does not test the function of atomic, so it can be replaced by new test cases
