[PATCH 1/2] libmm score and stubs
    Gedare Bloom
    gedare at rtems.org
    Wed Jul 24 16:19:59 UTC 2013
On Wed, Jul 24, 2013 at 11:02 AM, Rempel, Cynthia
<cynt6007 at vandals.uidaho.edu> wrote:
> Hi Hesham,
> Thanks for doing the stubs :)
> Could you pull all the implementation specific parts of mm.h and mm.inl into a header called mmimpl.h ?
> It would then match the header-style score is heading towards...
> If the no_memorymanagement.c is for devices without mm support, could you have the functions print out a "stub warning/error" message? That way the user knows not to rely on memory management...
I don't think we should have the stubs do anything in the normal case.
We could add something when RTEMS_DEBUG is enabled.
> Thanks!
> Cindy
> ________________________________________
> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Hesham AL-Matary [heshamelmatary at gmail.com]
> Sent: Tuesday, July 23, 2013 2:24 PM
> To: rtems-devel at rtems.org
> Subject: [PATCH 1/2] libmm score and stubs
>  c/src/lib/libcpu/shared/include/mm.h              | 23 +++++++
>  c/src/lib/libcpu/shared/src/no_memorymanagement.c | 17 +++++
>  cpukit/score/Makefile.am                          |  2 +
>  cpukit/score/include/rtems/score/mm.h             | 55 +++++++++++++++
>  cpukit/score/inline/rtems/score/mm.inl            | 82 +++++++++++++++++++++++
>  cpukit/score/preinstall.am                        |  8 +++
>  testsuites/libtests/Makefile.am                   |  2 +-
>  testsuites/libtests/configure.ac                  |  1 +
>  testsuites/libtests/mmtest1/Makefile.am           | 18 +++++
>  testsuites/libtests/mmtest1/init.c                | 41 ++++++++++++
>  testsuites/libtests/mmtest1/mmtest1.doc           |  1 +
>  testsuites/libtests/mmtest1/mmtests.scn           |  7 ++
>  testsuites/libtests/mmtest1/system.h              | 33 +++++++++
>  13 files changed, 289 insertions(+), 1 deletion(-)
>  create mode 100644 c/src/lib/libcpu/shared/include/mm.h
>  create mode 100644 c/src/lib/libcpu/shared/src/no_memorymanagement.c
>  create mode 100644 cpukit/score/include/rtems/score/mm.h
>  create mode 100644 cpukit/score/inline/rtems/score/mm.inl
>  create mode 100644 testsuites/libtests/mmtest1/Makefile.am
>  create mode 100644 testsuites/libtests/mmtest1/init.c
>  create mode 100644 testsuites/libtests/mmtest1/mmtest1.doc
>  create mode 100644 testsuites/libtests/mmtest1/mmtests.scn
>  create mode 100644 testsuites/libtests/mmtest1/system.h
> diff --git a/c/src/lib/libcpu/shared/include/mm.h b/c/src/lib/libcpu/shared/include/mm.h
> new file mode 100644
> index 0000000..02903f1
> --- /dev/null
> +++ b/c/src/lib/libcpu/shared/include/mm.h
> @@ -0,0 +1,23 @@
> + * Copyright (c) 2013 Gedare Bloom.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifndef __LIBCPU_MM_H
> +#define __LIBCPU_MM_H
> +#include <rtems/score/mm.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +void _CPU_Memory_management_Initialize(void);
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/shared/src/no_memorymanagement.c b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> index 0000000..f5380a0
> --- /dev/null
> +++ b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> @@ -0,0 +1,17 @@
> + * Copyright (c) 2013 Hesham AL-Matary
> +#include <rtems.h>
> +#include <libcpu/mm.h>
> +void _CPU_Memory_management_Initialize( void ) { }
> +void _CPU_Memory_management_Install_entry( uintptr_t base, size_t size, uint32_t flags ) { }
> +void _CPU_Memory_management_Uninstall_entry( uintptr_t base, size_t size ) { }
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 3f6e686..58a865b 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -30,6 +30,7 @@ include_rtems_score_HEADERS += include/rtems/score/protectedheap.h
>  include_rtems_score_HEADERS += include/rtems/score/interr.h
>  include_rtems_score_HEADERS += include/rtems/score/isr.h
>  include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
> +include_rtems_score_HEADERS += include/rtems/score/mm.h
>  include_rtems_score_HEADERS += include/rtems/score/object.h
>  include_rtems_score_HEADERS += include/rtems/score/percpu.h
>  include_rtems_score_HEADERS += include/rtems/score/priority.h
> @@ -90,6 +91,7 @@ include_rtems_score_HEADERS += inline/rtems/score/coremutex.inl
>  include_rtems_score_HEADERS += inline/rtems/score/coresem.inl
>  include_rtems_score_HEADERS += inline/rtems/score/heap.inl
>  include_rtems_score_HEADERS += inline/rtems/score/isr.inl
> +include_rtems_score_HEADERS += inline/rtems/score/mm.inl
>  include_rtems_score_HEADERS += inline/rtems/score/object.inl
>  include_rtems_score_HEADERS += inline/rtems/score/priority.inl
>  include_rtems_score_HEADERS += inline/rtems/score/prioritybitmap.inl
> diff --git a/cpukit/score/include/rtems/score/mm.h b/cpukit/score/include/rtems/score/mm.h
> index 0000000..c1f950d
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/mm.h
> @@ -0,0 +1,55 @@
> + * @file
> + * @brief Manages use of MPU/MMU units to provide memory management.
> + * Copyright (c) 2013 Hesham Al-Matary.
> +#ifndef _RTEMS_SCORE_MM_H
> +#define _RTEMS_SCORE_MM_H
> +/* @defgroup SuperCoreMM Memory Management Support
> + * @ingroup Score
> +#include <inttypes.h>
> +#ifdef RTEMS_SMP
> +#include <rtems/score/smplock.h>
> +#endif
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @brief _Memory_management_Region Flags defs
> +#define RTEMS_MM_REGION_PROTECTION_READ_ONLY   0x1
> +#define RTEMS_MM_REGION_PROTECTION_WRITE  0x2
> +//#define RTEMS_MM_REGION_PROTECTION_EXEC   0x4
> +#ifdef RTEMS_SMP
> +SMP_lock_Control mm_lock;
> +#endif
> +#ifndef __RTEMS_APPLICATION__
> +#include <rtems/score/mm.inl>
> +#endif
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/inline/rtems/score/mm.inl b/cpukit/score/inline/rtems/score/mm.inl
> index 0000000..765c147
> --- /dev/null
> +++ b/cpukit/score/inline/rtems/score/mm.inl
> @@ -0,0 +1,82 @@
> + * @file
> + * @brief Inlined Routines from the Memory Management Manager
> +# error "Never use <rtems/score/mm.inl> directly; include <rtems/score/mm.h> instead."
> +#endif
> +#ifndef _RTEMS_SCORE_MM_INL
> +#define _RTEMS_SCORE_MM_INL
> + * @addtogroup SuperCoreMM
> + * @brief Calls _CPU_Memory_management_Initialize.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Initialize( void )
> +#ifdef RTEMS_SMP
> +   _SMP_lock_Initialize( &mm_lock );
> +#endif
> +  _CPU_Memory_management_Initialize();
> + * @brief Calls _CPU_Memory_management_Install_entry.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Install_entry(
> +  uintptr_t base,
> +  size_t size,
> +  uint32_t attr
> +#ifdef RTEMS_SMP
> +  _SMP_lock_Acquire( &mm_lock );
> +#endif
> +  _CPU_Memory_management_Install_entry(base, size, attr);
> +#ifdef RTEMS_SMP
> +  _SMP_lock_Release( &mm_lock );
> +#endif
> + * @brief Calls _CPU_Memory_management_Uninstall_entry.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Uninstall_entry(
> +  uintptr_t base,
> +  size_t size
> +#ifdef RTEMS_SMP
> +#endif
> +  _CPU_Memory_management_Uninstall_entry(base, size);
> +#ifdef RTEMS_SMP
> +#endif
> +#endif
> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> index dc84b21..100f090 100644
> --- a/cpukit/score/preinstall.am
> +++ b/cpukit/score/preinstall.am
> @@ -103,6 +103,10 @@ $(PROJECT_INCLUDE)/rtems/score/isrlevel.h: include/rtems/score/isrlevel.h $(PROJ
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
> +$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
>  $(PROJECT_INCLUDE)/rtems/score/object.h: include/rtems/score/object.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.h
> @@ -298,6 +302,10 @@ $(PROJECT_INCLUDE)/rtems/score/isr.inl: inline/rtems/score/isr.inl $(PROJECT_INC
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isr.inl
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isr.inl
> +$(PROJECT_INCLUDE)/rtems/score/mm.inl: inline/rtems/score/mm.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.inl
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.inl
>  $(PROJECT_INCLUDE)/rtems/score/object.inl: inline/rtems/score/object.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.inl
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.inl
> diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
> index d1ffabc..d56398b 100644
> --- a/testsuites/libtests/Makefile.am
> +++ b/testsuites/libtests/Makefile.am
> @@ -16,7 +16,7 @@ SUBDIRS += flashdisk01
>  SUBDIRS += bspcmdline01 cpuuse devfs01 devfs02 devfs03 devfs04 \
>      deviceio01 devnullfatal01 dumpbuf01 gxx01 \
>      malloctest malloc02 malloc03 malloc04 malloc05 heapwalk \
> -    putenvtest monitor monitor02 rtmonuse stackchk stackchk01 \
> +    putenvtest monitor monitor02 mmtest1 rtmonuse stackchk stackchk01 \
>      termios termios01 termios02 termios03 termios04 termios05 \
>      termios06 termios07 termios08 \
>      rtems++ tztest block01 block02 block03 block04 block05 block06 block07 \
> diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
> index 741c603..c1dbb78 100644
> --- a/testsuites/libtests/configure.ac
> +++ b/testsuites/libtests/configure.ac
> @@ -85,6 +85,7 @@ malloc02/Makefile
>  malloc03/Makefile
>  malloc04/Makefile
>  malloc05/Makefile
> +mmtest1/Makefile
>  monitor/Makefile
>  monitor02/Makefile
>  mouse01/Makefile
> diff --git a/testsuites/libtests/mmtest1/Makefile.am b/testsuites/libtests/mmtest1/Makefile.am
> index 0000000..a08e557
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/Makefile.am
> @@ -0,0 +1,18 @@
> +rtems_tests_PROGRAMS = mmtest1
> +mmtest1_SOURCES = init.c system.h
> +dist_rtems_tests_DATA = mmtests.scn
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +LINK_OBJS = $(mmtest1_OBJECTS) $(mmtest1_LDADD)
> +LINK_LIBS = $(mmtest1_LDLIBS)
> +mmtest1$(EXEEXT): $(mmtest1_OBJECTS) $(mmtest1_DEPENDENCIES)
> +         @rm -f mmtest1$(EXEEXT)
> +         $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/libtests/mmtest1/init.c b/testsuites/libtests/mmtest1/init.c
> index 0000000..b110044
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/init.c
> @@ -0,0 +1,41 @@
> +/* Init
> + * This routine is the initialization task for this test program.
> + * Copyright (c) 2012 Hesham Al-Matary.
> +#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
> +#define CONFIGURE_INIT
> +#include "system.h"
> +#include <stdio.h>
> +#include <stdlib.h>
> +rtems_task Init(
> +  rtems_task_argument ignored
> +  puts( "\n\n*** Start of mmtest1 ***\n" );
> +  printf("Test 1: Installing Entry-1 \
> +and set it as Read only\n");
> +  _Memory_management_Install_entry( 0x00100000, 0x200000, RTEMS_MM_REGION_PROTECTION_READ_ONLY);
> +  printf("Test 2 : Installing Entry-2\
> +and set it as Write enabled\n");
> +  _Memory_management_Install_entry( 0x00400000, 0x100000, RTEMS_MM_REGION_PROTECTION_WRITE);
> +  printf( "\n\n*** End of mmtest1 ***\n" );
> +  exit( 0 );
> diff --git a/testsuites/libtests/mmtest1/mmtest1.doc b/testsuites/libtests/mmtest1/mmtest1.doc
> index 0000000..210a761
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/mmtest1.doc
> @@ -0,0 +1 @@
> +Simple tests that tries to install memory management entries.
> diff --git a/testsuites/libtests/mmtest1/mmtests.scn b/testsuites/libtests/mmtest1/mmtests.scn
> index 0000000..6ba15c2
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/mmtests.scn
> @@ -0,0 +1,7 @@
> +*** Start of mmtest1 ***
> +Test 1: Installing Entry-1 and set it as Read only
> +Test 2 : Installing Entry-2and set it as Write enabled
> +*** End of mmtest1 ***
> diff --git a/testsuites/libtests/mmtest1/system.h b/testsuites/libtests/mmtest1/system.h
> index 0000000..7560e1d
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/system.h
> @@ -0,0 +1,33 @@
> +/* system.h
> +#include <rtems.h>
> +/* functions */
> +rtems_task Init(
> +  rtems_task_argument argument
> +/* configuration information */
> +#include <bsp.h> /* for device driver prototypes */
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS            9
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> +#include <rtems/confdefs.h>
> +/* end of include file */
> 1.8.3.1
> rtems-devel mailing list
