[PATCH 1/2] libmm score and stubs
Rempel, Cynthia
cynt6007 at vandals.uidaho.edu
Wed Jul 24 16:43:24 UTC 2013
>________________________________________
>From: gedare at gwmail.gwu.edu [gedare at gwmail.gwu.edu] on behalf of Gedare Bloom [gedare at rtems.org]
>Sent: Wednesday, July 24, 2013 9:19 AM
>To: Rempel, Cynthia
>Cc: Hesham AL-Matary; rtems-devel at rtems.org
>Subject: Re: [PATCH 1/2] libmm score and stubs
>On Wed, Jul 24, 2013 at 11:02 AM, Rempel, Cynthia
><cynt6007 at vandals.uidaho.edu> wrote:
>> Hi Hesham,
>> Thanks for doing the stubs :)
>> Could you pull all the implementation specific parts of mm.h and mm.inl into a header called mmimpl.h ?
>> It would then match the header-style score is heading towards...
>> If the no_memorymanagement.c is for devices without mm support, could you have the functions print out a "stub warning/error" message? That way the user knows not to rely on memory management...
>I don't think we should have the stubs do anything in the normal case.
Why?
>We could add something when RTEMS_DEBUG is enabled.
