rtems-testing with gdb option
Sree Harsha Konduri sreehars at buffalo.edu
Mon Jul 29 03:30:27 UTC 2013
There was a small change in the file pc386.in that i made to get qemu to
connect to gdb, but gdb can't seem to find the rtems kernel binaries.
The change was to add GDBARGS = -s if -G option is specified.
Thanks,
Sree
On Sun, Jul 28, 2013 at 2:56 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>  Then it should start qemu with the right arguments to so it starts in gdb server. You will need to start gdb in another window and attach with a command like target remote :1234... From memory but that should be close.
> You can always check the qemu docs to get the port number but the simulator is separate from gdb so you need to test it as an external target.
> Sree harsha <sreehars at buffalo.edu> wrote:
>  It is for pc386 to test the globaledf scheduler
>  Sent from my Verizon Wireless 4G LTE Smartphone
> -------- Original message --------
> From: Joel Sherrill <Joel.Sherrill at OARcorp.com>
> Date: 07/28/2013 2:09 PM (GMT-05:00)
> To: Sree Harsha Konduri <sreehars at buffalo.edu>
> Cc: rtems-devel at rtems.org
> Subject: Re: rtems-testing with gdb option
> Depends on the simulator if that mode is supported. It is for simulators you run in a separate window from the gdb session.
> Which simulator?
> Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
>  Hello,
>  The rtems-testing module is provided with a -G option to put the
> executable to run in gdb mode, but this is not the case when we run it with
> -G. Is there something i am missing, can someone help me on this?
>  Thanks,
> Sree
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130728/fde60d2e/attachment-0001.html>
