rtems-testing with gdb option
Mon Jul 29 14:37:04 UTC 2013
gdb connects to qemu.
you may need to specify in gdb some extra information about the
locations of files, for example:
file /home/gedare/work/rtems/rtems/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
if you are repeatedly debugging the same file connecting "remotely" to
qemu, you may like to create a .gdbinit in the directory from which
you call gdb that contains the following:
file $PATHTOEXE
target remote localhost:1234
break Init
On Sun, Jul 28, 2013 at 11:30 PM, Sree Harsha Konduri
<sreehars at buffalo.edu> wrote:
> There was a small change in the file pc386.in that i made to get qemu to
> connect to gdb, but gdb can't seem to find the rtems kernel binaries.
> The change was to add GDBARGS = -s if -G option is specified.
> Thanks,
> Sree
> On Sun, Jul 28, 2013 at 2:56 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>
> wrote:
>> Then it should start qemu with the right arguments to so it starts in gdb
>> server. You will need to start gdb in another window and attach with a
>> command like target remote :1234... From memory but that should be close.
>> You can always check the qemu docs to get the port number but the
>> simulator is separate from gdb so you need to test it as an external target.
>> Sree harsha <sreehars at buffalo.edu> wrote:
>> It is for pc386 to test the globaledf scheduler
>> Sent from my Verizon Wireless 4G LTE Smartphone
>> -------- Original message --------
>> From: Joel Sherrill <Joel.Sherrill at OARcorp.com>
>> Date: 07/28/2013 2:09 PM (GMT-05:00)
>> To: Sree Harsha Konduri <sreehars at buffalo.edu>
>> Cc: rtems-devel at rtems.org
>> Subject: Re: rtems-testing with gdb option
>> Depends on the simulator if that mode is supported. It is for simulators
>> you run in a separate window from the gdb session.
>> Which simulator?
>> Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
>> Hello,
>> The rtems-testing module is provided with a -G option to put the
>> executable to run in gdb mode, but this is not the case when we run it with
>> -G. Is there something i am missing, can someone help me on this?
>> Thanks,
>> Sree
> rtems-devel mailing list
