[PATCH 01/12] rtems: Simplify rtems_task_mode()
Sebastian Huber
Wed Jun 12 15:12:27 UTC 2013
cpukit/rtems/src/taskmode.c | 10 ++++------
1 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
index 63fe29c..66cf505 100644
--- a/cpukit/rtems/src/taskmode.c
+++ b/cpukit/rtems/src/taskmode.c
@@ -42,8 +42,7 @@ rtems_status_code rtems_task_mode(
Thread_Control *executing;
RTEMS_API_Control *api;
ASR_Information *asr;
- bool is_asr_enabled = false;
- bool needs_asr_dispatching = false;
+ bool needs_asr_dispatching;
rtems_mode old_mode;
if ( !previous_mode_set )
@@ -69,7 +68,7 @@ rtems_status_code rtems_task_mode(
* These are generic thread scheduling characteristics.
if ( mask & RTEMS_PREEMPT_MASK )
- executing->is_preemptible = _Modes_Is_preempt(mode_set) ? true : false;
+ executing->is_preemptible = _Modes_Is_preempt( mode_set );
if ( mask & RTEMS_TIMESLICE_MASK ) {
if ( _Modes_Is_timeslice(mode_set) ) {
@@ -88,11 +87,10 @@ rtems_status_code rtems_task_mode(
* This is specific to the RTEMS API
- is_asr_enabled = false;
if ( mask & RTEMS_ASR_MASK ) {
- is_asr_enabled = _Modes_Is_asr_disabled( mode_set ) ? false : true;
+ bool is_asr_enabled = !_Modes_Is_asr_disabled( mode_set );
if ( is_asr_enabled != asr->is_enabled ) {
asr->is_enabled = is_asr_enabled;
_ASR_Swap_signals( asr );
1.7.7
