[PATCH 02/12] score: Add and use _Thread_Dispatch_is_enabled()
Sebastian Huber
Wed Jun 12 15:12:28 UTC 2013
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
c/src/lib/libbsp/powerpc/shared/startup/panic.c | 6 +-
c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c | 2 +-
c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c | 2 +-
c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c | 2 +-
c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c | 2 +-
cpukit/libcsupport/src/malloc_deferred.c | 2 +-
cpukit/libcsupport/src/realloc.c | 2 +-
cpukit/libcsupport/src/sup_fs_location.c | 2 +-
cpukit/rtems/src/clocktick.c | 2 +-
cpukit/score/cpu/lm32/irq.c | 2 +-
cpukit/score/cpu/nios2/nios2-iic-irq.c | 2 +-
cpukit/score/include/rtems/score/coremutex.h | 2 +-
cpukit/score/include/rtems/score/threaddispatch.h | 45 ++++++---------------
cpukit/score/src/heapfree.c | 2 +-
cpukit/score/src/pheapwalk.c | 2 +-
cpukit/score/src/threaddispatchdisablelevel.c | 8 ----
testsuites/support/include/tmacros.h | 6 +-
17 files changed, 32 insertions(+), 59 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/panic.c b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
index 958a06d..0aefe8f 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/panic.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
@@ -56,12 +56,12 @@ void _BSP_Fatal_error(unsigned int v)
printk(" UNKNOWN (0x%x)\n",THESRC);
break;
- if ( _Thread_Dispatch_in_critical_section() )
+ if ( _Thread_Dispatch_is_enabled() )
+ printk("enabled\n");
+ else
printk(
" Error occurred in a Thread Dispatching DISABLED context (level %i)\n",
_Thread_Dispatch_get_disable_level());
- else
- printk("enabled\n");
if ( _ISR_Nest_level ) {
printk(
diff --git a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
index 1c14cc0..9776457 100644
--- a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
@@ -170,7 +170,7 @@ void __ISR_Handler( uint32_t vector)
return;
- if ( _Thread_Dispatch_in_critical_section() ) {
+ if ( !_Thread_Dispatch_is_enabled() ) {
return;
diff --git a/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
index d141a2d..69134d9 100644
--- a/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c
@@ -172,7 +172,7 @@ void __ISR_Handler( uint32_t vector)
return;
return;
diff --git a/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
index fcc867f..77945ae 100644
--- a/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c
@@ -95,7 +95,7 @@ void __ISR_Handler( uint32_t vector)
return;
return;
diff --git a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
index 678e23c..a9a24c9 100644
--- a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
@@ -69,7 +69,7 @@ void __ISR_Handler( uint32_t vector)
return;
return;
diff --git a/cpukit/libcsupport/src/malloc_deferred.c b/cpukit/libcsupport/src/malloc_deferred.c
index d1ad56f..a2e95ea 100644
--- a/cpukit/libcsupport/src/malloc_deferred.c
+++ b/cpukit/libcsupport/src/malloc_deferred.c
@@ -31,7 +31,7 @@ RTEMS_CHAIN_DEFINE_EMPTY(RTEMS_Malloc_GC_list);
bool malloc_is_system_state_OK(void)
return false;
if ( _ISR_Nest_level > 0 )
diff --git a/cpukit/libcsupport/src/realloc.c b/cpukit/libcsupport/src/realloc.c
index eee6f79..a831cae 100644
--- a/cpukit/libcsupport/src/realloc.c
+++ b/cpukit/libcsupport/src/realloc.c
@@ -38,7 +38,7 @@ void *realloc(
if (_System_state_Is_up(_System_state_Get())) {
- if (_Thread_Dispatch_in_critical_section())
+ if (!_Thread_Dispatch_is_enabled())
return (void *) 0;
if (_ISR_Nest_level > 0)
diff --git a/cpukit/libcsupport/src/sup_fs_location.c b/cpukit/libcsupport/src/sup_fs_location.c
index 2ce5145..b4713c5 100644
--- a/cpukit/libcsupport/src/sup_fs_location.c
+++ b/cpukit/libcsupport/src/sup_fs_location.c
@@ -178,7 +178,7 @@ void rtems_filesystem_global_location_release(
rtems_filesystem_global_location_t *global_loc
- if (!_Thread_Dispatch_in_critical_section()) {
+ if (_Thread_Dispatch_is_enabled()) {
release_with_count(global_loc, 1);
} else {
if (global_loc->deferred_released_count == 0) {
diff --git a/cpukit/rtems/src/clocktick.c b/cpukit/rtems/src/clocktick.c
index 1bd91ac..8467fd6 100644
--- a/cpukit/rtems/src/clocktick.c
+++ b/cpukit/rtems/src/clocktick.c
@@ -35,7 +35,7 @@ rtems_status_code rtems_clock_tick( void )
_Scheduler_Tick();
if ( _Thread_Is_context_switch_necessary() &&
- _Thread_Is_dispatching_enabled() )
+ _Thread_Dispatch_is_enabled() )
_Thread_Dispatch();
return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/cpu/lm32/irq.c b/cpukit/score/cpu/lm32/irq.c
index 37e9a28..b69a65d 100644
--- a/cpukit/score/cpu/lm32/irq.c
+++ b/cpukit/score/cpu/lm32/irq.c
@@ -72,7 +72,7 @@ void __ISR_Handler(uint32_t vector, CPU_Interrupt_frame *ifr)
return;
- if ( _Thread_Dispatch_necessary && !_Thread_Dispatch_in_critical_section() ) {
+ if ( _Thread_Dispatch_necessary && _Thread_Dispatch_is_enabled() ) {
/* save off our stack frame so the context switcher can get to it */
_exception_stack_frame = ifr;
diff --git a/cpukit/score/cpu/nios2/nios2-iic-irq.c b/cpukit/score/cpu/nios2/nios2-iic-irq.c
index 31e2ba9..1f29365 100644
--- a/cpukit/score/cpu/nios2/nios2-iic-irq.c
+++ b/cpukit/score/cpu/nios2/nios2-iic-irq.c
@@ -117,7 +117,7 @@ void __ISR_Handler(void)
stack_ptr = _old_stack_ptr;
#endif
- if( !_Thread_Dispatch_in_critical_section() )
+ if( _Thread_Dispatch_is_enabled() )
if ( _Thread_Dispatch_necessary ) {
_CPU_ISR_Enable( level );
diff --git a/cpukit/score/include/rtems/score/coremutex.h b/cpukit/score/include/rtems/score/coremutex.h
index 10dfe06..f6c377c 100644
--- a/cpukit/score/include/rtems/score/coremutex.h
+++ b/cpukit/score/include/rtems/score/coremutex.h
@@ -352,7 +352,7 @@ void _CORE_mutex_Seize_interrupt_blocking(
#define _CORE_mutex_Check_dispatch_for_seize(_wait) 0
#else
#define _CORE_mutex_Check_dispatch_for_seize(_wait) \
- (_Thread_Dispatch_in_critical_section() \
+ (!_Thread_Dispatch_is_enabled() \
&& (_wait) \
&& (_System_state_Get() >= SYSTEM_STATE_BEGIN_MULTITASKING))
#endif
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index 0333e9b..e3065da 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -46,6 +46,19 @@ extern "C" {
SCORE_EXTERN volatile uint32_t _Thread_Dispatch_disable_level;
+ * @brief Indicates if the executing thread is inside a thread dispatch
+ * critical section.
+ * @retval true Thread dispatching is enabled.
+ * @retval false The executing thread is inside a thread dispatch critical
+ * section and dispatching is not allowed.
+RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
+ return _Thread_Dispatch_disable_level == 0;
#if defined(RTEMS_SMP)
typedef struct {
SMP_lock_Control lock;
@@ -68,14 +81,6 @@ SCORE_EXTERN volatile uint32_t _Thread_Dispatch_disable_level;
void _Thread_Dispatch_initialization(void);
- * @brief Checks if thread dispatch says that we are in a critical section.
- * This routine returns true if thread dispatch indicates
- * that we are in a critical section.
- bool _Thread_Dispatch_in_critical_section(void);
* @brief Returns value of the the thread dispatch level.
* This routine returns value of the the thread dispatch level.
@@ -105,20 +110,6 @@ SCORE_EXTERN volatile uint32_t _Thread_Dispatch_disable_level;
uint32_t _Thread_Dispatch_decrement_disable_level(void);
#else /* RTEMS_SMP */
- * @brief _Thread_Dispatch_in_critical_section
- RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_in_critical_section(void)
- if ( _Thread_Dispatch_disable_level == 0 )
- return false;
- return true;
* @brief Get thread dispatch disable level.
@@ -246,16 +237,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
_Thread_Dispatch_decrement_disable_level();
- * This function returns true if dispatching is disabled, and false
- * otherwise.
-RTEMS_INLINE_ROUTINE bool _Thread_Is_dispatching_enabled( void )
- return ( _Thread_Dispatch_in_critical_section() == false );
#ifdef __cplusplus
diff --git a/cpukit/score/src/heapfree.c b/cpukit/score/src/heapfree.c
index d53a54d..30a84a0 100644
--- a/cpukit/score/src/heapfree.c
+++ b/cpukit/score/src/heapfree.c
@@ -87,7 +87,7 @@
* is the task stack of a thread that deletes itself. The thread dispatch
* disable level is a way to detect this use case.
- if ( !_Thread_Dispatch_in_critical_section() ) {
+ if ( _Thread_Dispatch_is_enabled() ) {
Heap_Block *const next = block->Protection_begin.next_delayed_free_block;
if ( next == NULL ) {
_Heap_Protection_delay_block_free( heap, block );
diff --git a/cpukit/score/src/pheapwalk.c b/cpukit/score/src/pheapwalk.c
index 12b2a6d..d06d8bc 100644
--- a/cpukit/score/src/pheapwalk.c
+++ b/cpukit/score/src/pheapwalk.c
@@ -37,7 +37,7 @@ bool _Protected_heap_Walk(
* NOTE: Dispatching is also disabled during initialization.
- if ( _Thread_Dispatch_in_critical_section() == false ) {
_RTEMS_Lock_allocator();
status = _Heap_Walk( the_heap, source, do_dump );
_RTEMS_Unlock_allocator();
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index 154a6af..1f84bfe 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -39,14 +39,6 @@ void _Thread_Dispatch_initialization( void )
_Thread_Dispatch_set_disable_level( 1 );
-bool _Thread_Dispatch_in_critical_section(void)
- return false;
- return true;
uint32_t _Thread_Dispatch_get_disable_level(void)
return _Thread_Dispatch_disable_level;
diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
index c2878dd..6ab6e23 100644
--- a/testsuites/support/include/tmacros.h
+++ b/testsuites/support/include/tmacros.h
@@ -54,13 +54,13 @@ extern "C" {
#define check_dispatch_disable_level( _expect ) \
do { \
if ( (_expect) != -1 \
- && ((_Thread_Dispatch_in_critical_section() == false && (_expect) != 0) \
- || (_Thread_Dispatch_in_critical_section() && (_expect) == 0)) \
+ && ((!_Thread_Dispatch_is_enabled() == false && (_expect) != 0) \
+ || (!_Thread_Dispatch_is_enabled() && (_expect) == 0)) \
printk( \
"\n_Thread_Dispatch_disable_level is (%" PRId32 \
") not %d detected at %s:%d\n", \
- _Thread_Dispatch_in_critical_section(), (_expect), __FILE__, __LINE__ ); \
+ !_Thread_Dispatch_is_enabled(), (_expect), __FILE__, __LINE__ ); \
FLUSH_OUTPUT(); \
rtems_test_exit( 1 ); \
1.7.7
