[PATCH 09/12] scheduler: Add and use _Scheduler_default_Tick()
    Gedare Bloom
    gedare at rtems.org
    Thu Jun 13 15:52:09 UTC 2013
On Wed, Jun 12, 2013 at 11:12 AM, Sebastian Huber
> Delete _Scheduler_priority_Tick().  Use _Processors_Count for default
> tick operation.  Delete _Scheduler_simple_smp_Tick().
>  cpukit/score/Makefile.am                           |    4 +-
>  cpukit/score/include/rtems/score/scheduler.h       |    8 ++
>  cpukit/score/include/rtems/score/schedulercbs.h    |    2 +-
>  cpukit/score/include/rtems/score/scheduleredf.h    |    2 +-
>  .../score/include/rtems/score/schedulerpriority.h  |   11 +--
>  cpukit/score/include/rtems/score/schedulersimple.h |    2 +-
>  .../score/include/rtems/score/schedulersimplesmp.h |   11 +--
>  cpukit/score/src/schedulerdefaulttick.c            |   92 +++++++++++++++++
>  cpukit/score/src/schedulerprioritytick.c           |   83 ---------------
>  cpukit/score/src/schedulersimplesmptick.c          |  107 --------------------
>  10 files changed, 107 insertions(+), 215 deletions(-)
>  create mode 100644 cpukit/score/src/schedulerdefaulttick.c
>  delete mode 100644 cpukit/score/src/schedulerprioritytick.c
>  delete mode 100644 cpukit/score/src/schedulersimplesmptick.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 9bc40b1..dc018f0 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -138,7 +138,7 @@ endif
>  if HAS_SMP
>  libscore_a_SOURCES += src/isrsmp.c src/smp.c \
>      src/schedulersimplesmpblock.c src/schedulersimplesmpschedule.c \
> -    src/schedulersimplesmpunblock.c src/schedulersimplesmptick.c
> +    src/schedulersimplesmpunblock.c
>  endif
>  ## CORE_APIMUTEX_C_FILES
> @@ -199,12 +199,12 @@ libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
>  ## SCHEDULER_C_FILES
>  libscore_a_SOURCES += src/scheduler.c
> +libscore_a_SOURCES += src/schedulerdefaulttick.c
>  libscore_a_SOURCES += src/schedulerdefaultstartidle.c
>  ## SCHEDULERPRIORITY_C_FILES
>  libscore_a_SOURCES += src/schedulerpriority.c \
>      src/schedulerpriorityallocate.c \
> -    src/schedulerprioritytick.c \
>      src/schedulerpriorityblock.c \
>      src/schedulerpriorityenqueue.c \
>      src/schedulerpriorityenqueuefirst.c \
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index 930412f..6e3b35f 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -150,6 +150,14 @@ extern Scheduler_Control  _Scheduler;
>  void _Scheduler_Handler_initialization( void );
> + * @brief Performs tick operations depending on the CPU budget algorithm for
> + * each executing thread.
> + * This routine is invoked as part of processing each clock tick.
> +void _Scheduler_default_Tick( void );
>   * @brief Unblocks the thread.
>   * @param[in/out] thread An idle thread.
> diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
> index 41f8ab0..bec989f 100644
> --- a/cpukit/score/include/rtems/score/schedulercbs.h
> +++ b/cpukit/score/include/rtems/score/schedulercbs.h
> @@ -60,7 +60,7 @@ extern "C" {
>      _Scheduler_EDF_Extract,          /* extract entry point */ \
>      _Scheduler_EDF_Priority_compare, /* compares two priorities */ \
>      _Scheduler_CBS_Release_job,      /* new period of task */ \
> -    _Scheduler_priority_Tick,        /* tick entry point */ \
> +    _Scheduler_default_Tick,         /* tick entry point */ \
>      _Scheduler_default_Start_idle    /* start idle entry point */ \
> diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
> index 7846067..090974b 100644
> --- a/cpukit/score/include/rtems/score/scheduleredf.h
> +++ b/cpukit/score/include/rtems/score/scheduleredf.h
> @@ -53,7 +53,7 @@ extern "C" {
>      _Scheduler_EDF_Release_job,      /* new period of task */ \
> diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
> index f0582c1..f6fdaff 100644
> --- a/cpukit/score/include/rtems/score/schedulerpriority.h
> +++ b/cpukit/score/include/rtems/score/schedulerpriority.h
> @@ -52,7 +52,7 @@ extern "C" {
>      _Scheduler_priority_Extract,          /* extract entry point */ \
>      _Scheduler_priority_Priority_compare, /* compares two priorities */ \
>      _Scheduler_priority_Release_job,      /* new period of task */ \
> @@ -226,15 +226,6 @@ void _Scheduler_priority_Release_job (
> - *  @brief Determines if the current thread allows timeslicing.
> - *  This routine is invoked as part of processing each clock tick.
> - *  It is responsible for determining if the current thread allows
> - *  timeslicing and, if so, when its timeslice expires.
> -void _Scheduler_priority_Tick( void );
>   *  This is the major bit map.
>  extern volatile Priority_bit_map_Control _Priority_Major_bit_map;
> diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
> index 47b74be..0cdc8fc 100644
> --- a/cpukit/score/include/rtems/score/schedulersimple.h
> +++ b/cpukit/score/include/rtems/score/schedulersimple.h
> @@ -50,7 +50,7 @@ extern "C" {
>      _Scheduler_simple_Extract,            /* extract entry point */ \
> diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> index 63213c6..baac7b2 100644
> --- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
> +++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> @@ -62,7 +62,7 @@ extern "C" {
> -    _Scheduler_simple_smp_Tick            /* tick entry point */ \
> +    _Scheduler_default_Tick               /* tick entry point */ \
> @@ -102,15 +102,6 @@ void _Scheduler_simple_smp_Unblock(
>    Thread_Control *the_thread
> - *  @brief Invoked as part of processing each SMP clock tick.
> -void _Scheduler_simple_smp_Tick( void );
>  #ifdef __cplusplus
>  #endif
> diff --git a/cpukit/score/src/schedulerdefaulttick.c b/cpukit/score/src/schedulerdefaulttick.c
> new file mode 100644
> index 0000000..a291edc
> --- /dev/null
> +++ b/cpukit/score/src/schedulerdefaulttick.c
> @@ -0,0 +1,92 @@
> + * @file
> + * @brief Priority Scheduler At Tick Handler
s/Priority/Default  ?
> + * @ingroup ScoreScheduler
> + *  COPYRIGHT (c) 1989-2009.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#if HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/system.h>
> +#include <rtems/score/scheduler.h>
> +#include <rtems/score/thread.h>
> +static void _Scheduler_default_Tick_for_executing( Thread_Control *executing )
> +  #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> +     *  Increment the number of ticks this thread has been executing
> +    executing->cpu_time_used++;
> +  #endif
> +   *  If the thread is not preemptible or is not ready, then
> +   *  just return.
> +  if ( !executing->is_preemptible )
> +    return;
> +  if ( !_States_Is_ready( executing->current_state ) )
> +    return;
> +   *  The cpu budget algorithm determines what happens next.
> +  switch ( executing->budget_algorithm ) {
> +    case THREAD_CPU_BUDGET_ALGORITHM_NONE:
> +      break;
> +    case THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE:
> +    #if defined(RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE)
> +      case THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE:
> +    #endif
> +      if ( (int)(--executing->cpu_time_budget) <= 0 ) {
> +         *  A yield performs the ready chain mechanics needed when
> +         *  resetting a timeslice.  If no other thread's are ready
> +         *  at the priority of the currently executing thread, then the
> +         *  executing thread's timeslice is reset.  Otherwise, the
> +         *  currently executing thread is placed at the rear of the
> +         *  FIFO for this priority and a new heir is selected.
> +        _Scheduler_Yield_with_thread( executing );
> +        executing->cpu_time_budget = _Thread_Ticks_per_timeslice;
> +      break;
> +    #if defined(RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT)
> +      case THREAD_CPU_BUDGET_ALGORITHM_CALLOUT:
> +       if ( --executing->cpu_time_budget == 0 )
> +         (*executing->budget_callout)( executing );
> +       break;
> +    #endif
> +  uint32_t processor_count = _Processors_Count;
> +  uint32_t processor;
> +  for ( processor = 0 ; processor < processor_count ; ++processor ) {
> +    _Scheduler_default_Tick_for_executing(
> +      _Per_CPU_Information[ processor ].executing
> diff --git a/cpukit/score/src/schedulerprioritytick.c b/cpukit/score/src/schedulerprioritytick.c
> deleted file mode 100644
> index 8fa739c..0000000
> --- a/cpukit/score/src/schedulerprioritytick.c
> +++ /dev/null
> @@ -1,83 +0,0 @@
> - * @file
> - * @brief Priority Scheduler At Tick Handler
> - * @ingroup ScoreScheduler
> - *  COPYRIGHT (c) 1989-2009.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.com/license/LICENSE.
> -#if HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/system.h>
> -#include <rtems/score/schedulerpriority.h>
> -  Thread_Control *executing;
> -  executing = _Thread_Executing;
> -  #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> -     *  Increment the number of ticks this thread has been executing
> -    executing->cpu_time_used++;
> -  #endif
> -   *  If the thread is not preemptible or is not ready, then
> -   *  just return.
> -  if ( !executing->is_preemptible )
> -    return;
> -  if ( !_States_Is_ready( executing->current_state ) )
> -    return;
> -   *  The cpu budget algorithm determines what happens next.
> -  switch ( executing->budget_algorithm ) {
> -    case THREAD_CPU_BUDGET_ALGORITHM_NONE:
> -      break;
> -    case THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE:
> -    #if defined(RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE)
> -      case THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE:
> -    #endif
> -      if ( (int)(--executing->cpu_time_budget) <= 0 ) {
> -         *  A yield performs the ready chain mechanics needed when
> -         *  resetting a timeslice.  If no other thread's are ready
> -         *  at the priority of the currently executing thread, then the
> -         *  executing thread's timeslice is reset.  Otherwise, the
> -         *  currently executing thread is placed at the rear of the
> -         *  FIFO for this priority and a new heir is selected.
> -        _Scheduler_Yield_with_thread( executing );
> -        executing->cpu_time_budget = _Thread_Ticks_per_timeslice;
> -      break;
> -    #if defined(RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT)
> -      case THREAD_CPU_BUDGET_ALGORITHM_CALLOUT:
> -       if ( --executing->cpu_time_budget == 0 )
> -         (*executing->budget_callout)( executing );
> -       break;
> -    #endif
> diff --git a/cpukit/score/src/schedulersimplesmptick.c b/cpukit/score/src/schedulersimplesmptick.c
> index 72f8b1f..0000000
> --- a/cpukit/score/src/schedulersimplesmptick.c
> +++ /dev/null
> @@ -1,107 +0,0 @@
> - *  @file
> - *  @brief Scheduler Simple SMP Tick Method
> -#if HAVE_CONFIG_H
> -#endif
> -#include <rtems/score/schedulersimplesmp.h>
> -#include <rtems/score/smp.h>
> -static void _Scheduler_simple_smp_Tick_helper(
> -  int cpu
> -  ISR_Level       level;
> -  executing = _Per_CPU_Information[cpu].executing;
> -  #endif
> -   *  just return.
> -    return;
> -    return;
> -      break;
> -    #endif
> -         *  In the SMP case, we do the chain manipulation for every
> -         *  CPU, then schedule after all CPUs have been evaluated.
> -        _ISR_Disable( level );
> -          _Scheduler_simple_Ready_queue_requeue( &_Scheduler, executing );
> -        _ISR_Enable( level );
> -      break;
> -       break;
> -    #endif
> -  uint32_t        cpu;
> -   *  Iterate over all cores, updating time slicing information
> -   *  and logically performing a yield.  Then perform a schedule
> -   *  operation to account for all the changes.
> -  for ( cpu=0 ; cpu < _SMP_Processor_count ; cpu++ ) {
> -    _Scheduler_simple_smp_Tick_helper( cpu );
> -  _Scheduler_simple_smp_Schedule();
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
