[PATCH] bsps/powerpc: Delete bsp_exceptions_in_RAM
Sebastian Huber
Thu Jun 20 10:05:24 UTC 2013
Delete ppc_exc_vector_base. Add and use
ppc_exc_initialize_with_vector_base().
.../libbsp/powerpc/mpc55xxevb/startup/bspstart.c | 8 +-
c/src/lib/libbsp/powerpc/psim/startup/bspstart.c | 10 +--
c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c | 6 +-
c/src/lib/libbsp/powerpc/qoriq/startup/smp.c | 6 +-
.../lib/libbsp/powerpc/t32mppc/startup/bspstart.c | 6 +-
.../new-exceptions/bspsupport/ppc_exc_address.c | 13 +----
.../new-exceptions/bspsupport/ppc_exc_initialize.c | 61 +++++++++++---------
.../new-exceptions/bspsupport/ppc_exc_prologue.c | 14 ++++-
.../powerpc/new-exceptions/bspsupport/vectors.h | 57 +++++++++---------
9 files changed, 93 insertions(+), 88 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c
index a679abd..32899ee 100644
--- a/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c
@@ -105,11 +105,11 @@ void bsp_start(void)
bsp_clicks_per_usec = bsp_clock_speed / 1000000;
/* Initialize exceptions */
- ppc_exc_vector_base = (uint32_t) mpc55xx_exc_vector_base;
- ppc_exc_initialize(
+ ppc_exc_initialize_with_vector_base(
PPC_INTERRUPT_DISABLE_MASK_DEFAULT,
- (uintptr_t) bsp_section_work_begin,
- rtems_configuration_get_interrupt_stack_size()
+ (uintptr_t) bsp_section_work_begin,
+ rtems_configuration_get_interrupt_stack_size(),
+ mpc55xx_exc_vector_base
#ifndef PPC_EXC_CONFIG_USE_FIXED_HANDLER
ppc_exc_set_handler(ASM_ALIGN_VECTOR, ppc_exc_alignment_handler);
diff --git a/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c b/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
index 9ae6f7b..c58915c 100644
--- a/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
@@ -94,17 +94,13 @@ void bsp_start( void )
BSP_time_base_divisor = 1;
- * The simulator likes the exception table to be at 0xfff00000.
- bsp_exceptions_in_RAM = FALSE;
* Initialize default raw exception handlers.
+ (void *) 0xfff00000
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
index 9264fab..c6f6dd9 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
@@ -107,11 +107,11 @@ void bsp_start(void)
PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS(BOOKE_TCR, BOOKE_TCR_DIE);
/* Initialize exception handler */
- ppc_exc_vector_base = (uint32_t) bsp_exc_vector_base;
+ bsp_exc_vector_base
/* Now it is possible to make the code execute only */
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
index 595729a..30bcb7b 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
@@ -112,11 +112,11 @@ void qoriq_secondary_cpu_initialize(void)
(uintptr_t) _Per_CPU_Information[1].interrupt_stack_low,
diff --git a/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c b/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
index 089c1c4..b91ff43 100644
--- a/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
@@ -64,11 +64,11 @@ void bsp_start(void)
get_ppc_cpu_revision();
/* Initalize interrupt support */
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c
index e061f5b..6b8b64f 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c
@@ -30,10 +30,6 @@
#include <bsp/vectors.h>
-bool bsp_exceptions_in_RAM = true;
-uint32_t ppc_exc_vector_base = 0;
* XXX: These values are choosen to directly generate the vector offsets for an
* e200z1 which has hard wired IVORs (IVOR0=0x00, IVOR1=0x10, IVOR2=0x20, ...).
@@ -61,9 +57,8 @@ static const uint8_t ivor_values [] = {
[ASM_E500_PERFMON_VECTOR] = 19
-void *ppc_exc_vector_address(unsigned vector)
+void *ppc_exc_vector_address(unsigned vector, void *vector_base)
- uintptr_t vector_base = 0xfff00000;
uintptr_t vector_offset = vector << 8;
if (ppc_cpu_has_altivec()) {
@@ -101,9 +96,5 @@ void *ppc_exc_vector_address(unsigned vector)
- if (bsp_exceptions_in_RAM) {
- vector_base = ppc_exc_vector_base;
- return (void *) (vector_base + vector_offset);
+ return (void *) ((uintptr_t) vector_base + vector_offset);
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
index 31c9881..6ac9880 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
@@ -100,10 +100,10 @@ uint32_t ppc_exc_cache_wb_check = 1;
#define MTIVPR(prefix) __asm__ volatile ("mtivpr %0" : : "r" (prefix))
#define MTIVOR(x, vec) __asm__ volatile ("mtivor"#x" %0" : : "r" (vec))
-static void ppc_exc_initialize_booke(void)
+static void ppc_exc_initialize_booke(void *vector_base)
/* Interupt vector prefix register */
- MTIVPR(ppc_exc_vector_base);
+ MTIVPR((uint32_t) vector_base);
if (
ppc_cpu_is_specific_e200(PPC_e200z0)
@@ -117,29 +117,29 @@ static void ppc_exc_initialize_booke(void)
/* Interupt vector offset registers */
- MTIVOR(0, ppc_exc_vector_address(ASM_BOOKE_CRIT_VECTOR));
- MTIVOR(1, ppc_exc_vector_address(ASM_MACH_VECTOR));
- MTIVOR(2, ppc_exc_vector_address(ASM_PROT_VECTOR));
- MTIVOR(3, ppc_exc_vector_address(ASM_ISI_VECTOR));
- MTIVOR(4, ppc_exc_vector_address(ASM_EXT_VECTOR));
- MTIVOR(5, ppc_exc_vector_address(ASM_ALIGN_VECTOR));
- MTIVOR(6, ppc_exc_vector_address(ASM_PROG_VECTOR));
- MTIVOR(7, ppc_exc_vector_address(ASM_FLOAT_VECTOR));
- MTIVOR(8, ppc_exc_vector_address(ASM_SYS_VECTOR));
- MTIVOR(9, ppc_exc_vector_address(ASM_BOOKE_APU_VECTOR));
- MTIVOR(10, ppc_exc_vector_address(ASM_BOOKE_DEC_VECTOR));
- MTIVOR(11, ppc_exc_vector_address(ASM_BOOKE_FIT_VECTOR));
- MTIVOR(12, ppc_exc_vector_address(ASM_BOOKE_WDOG_VECTOR));
- MTIVOR(13, ppc_exc_vector_address(ASM_BOOKE_DTLBMISS_VECTOR));
- MTIVOR(14, ppc_exc_vector_address(ASM_BOOKE_ITLBMISS_VECTOR));
- MTIVOR(15, ppc_exc_vector_address(ASM_BOOKE_DEBUG_VECTOR));
+ MTIVOR(0, ppc_exc_vector_address(ASM_BOOKE_CRIT_VECTOR, vector_base));
+ MTIVOR(1, ppc_exc_vector_address(ASM_MACH_VECTOR, vector_base));
+ MTIVOR(2, ppc_exc_vector_address(ASM_PROT_VECTOR, vector_base));
+ MTIVOR(3, ppc_exc_vector_address(ASM_ISI_VECTOR, vector_base));
+ MTIVOR(4, ppc_exc_vector_address(ASM_EXT_VECTOR, vector_base));
+ MTIVOR(5, ppc_exc_vector_address(ASM_ALIGN_VECTOR, vector_base));
+ MTIVOR(6, ppc_exc_vector_address(ASM_PROG_VECTOR, vector_base));
+ MTIVOR(7, ppc_exc_vector_address(ASM_FLOAT_VECTOR, vector_base));
+ MTIVOR(8, ppc_exc_vector_address(ASM_SYS_VECTOR, vector_base));
+ MTIVOR(9, ppc_exc_vector_address(ASM_BOOKE_APU_VECTOR, vector_base));
+ MTIVOR(10, ppc_exc_vector_address(ASM_BOOKE_DEC_VECTOR, vector_base));
+ MTIVOR(11, ppc_exc_vector_address(ASM_BOOKE_FIT_VECTOR, vector_base));
+ MTIVOR(12, ppc_exc_vector_address(ASM_BOOKE_WDOG_VECTOR, vector_base));
+ MTIVOR(13, ppc_exc_vector_address(ASM_BOOKE_DTLBMISS_VECTOR, vector_base));
+ MTIVOR(14, ppc_exc_vector_address(ASM_BOOKE_ITLBMISS_VECTOR, vector_base));
+ MTIVOR(15, ppc_exc_vector_address(ASM_BOOKE_DEBUG_VECTOR, vector_base));
if (ppc_cpu_is_e200() || ppc_cpu_is_e500()) {
- MTIVOR(32, ppc_exc_vector_address(ASM_E500_SPE_UNAVAILABLE_VECTOR));
- MTIVOR(33, ppc_exc_vector_address(ASM_E500_EMB_FP_DATA_VECTOR));
- MTIVOR(34, ppc_exc_vector_address(ASM_E500_EMB_FP_ROUND_VECTOR));
+ MTIVOR(32, ppc_exc_vector_address(ASM_E500_SPE_UNAVAILABLE_VECTOR, vector_base));
+ MTIVOR(33, ppc_exc_vector_address(ASM_E500_EMB_FP_DATA_VECTOR, vector_base));
+ MTIVOR(34, ppc_exc_vector_address(ASM_E500_EMB_FP_ROUND_VECTOR, vector_base));
if (ppc_cpu_is_specific_e200(PPC_e200z7) || ppc_cpu_is_e500()) {
- MTIVOR(35, ppc_exc_vector_address(ASM_E500_PERFMON_VECTOR));
+ MTIVOR(35, ppc_exc_vector_address(ASM_E500_PERFMON_VECTOR, vector_base));
@@ -151,10 +151,11 @@ static void ppc_exc_fatal_error(void)
-void ppc_exc_initialize(
+void ppc_exc_initialize_with_vector_base(
uint32_t interrupt_disable_mask,
uintptr_t interrupt_stack_begin,
- uintptr_t interrupt_stack_size
+ uintptr_t interrupt_stack_size,
+ void *vector_base
rtems_status_code sc = RTEMS_SUCCESSFUL;
@@ -208,18 +209,24 @@ void ppc_exc_initialize(
#endif /* PPC_EXC_CONFIG_BOOKE_ONLY */
if (ppc_cpu_is_bookE() == PPC_BOOKE_STD || ppc_cpu_is_bookE() == PPC_BOOKE_E500) {
- ppc_exc_initialize_booke();
+ ppc_exc_initialize_booke(vector_base);
for (vector = 0; vector <= LAST_VALID_EXC; ++vector) {
ppc_exc_category category = ppc_exc_category_for_vector(categories, vector);
if (category != PPC_EXC_INVALID) {
- void *const vector_address = ppc_exc_vector_address(vector);
+ void *const vector_address = ppc_exc_vector_address(vector, vector_base);
uint32_t prologue [16];
size_t prologue_size = sizeof(prologue);
- sc = ppc_exc_make_prologue(vector, category, prologue, &prologue_size);
+ sc = ppc_exc_make_prologue(
+ vector,
+ vector_base,
+ category,
+ prologue,
+ &prologue_size
if (sc != RTEMS_SUCCESSFUL) {
ppc_exc_fatal_error();
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c
index 7518f5e..ec109dc 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c
@@ -63,6 +63,7 @@ static const uint32_t *const ppc_exc_prologue_templates [] = {
static bool ppc_exc_create_branch_op(
unsigned vector,
+ void *vector_base,
uint32_t *prologue,
@@ -72,7 +73,8 @@ static bool ppc_exc_create_branch_op(
static const uintptr_t BRANCH_OP_ABS = 0x2;
static const uintptr_t BRANCH_OP_MSK = 0x3ffffff;
size_t branch_op_index = prologue_size / 4 - 1;
- uintptr_t vector_address = (uintptr_t) ppc_exc_vector_address(vector);
+ uintptr_t vector_address =
+ (uintptr_t) ppc_exc_vector_address(vector, vector_base);
uintptr_t branch_op_address = vector_address + 4 * branch_op_index;
/* This value may have BRANCH_OP_LINK set */
@@ -101,6 +103,7 @@ static bool ppc_exc_create_branch_op(
rtems_status_code ppc_exc_make_prologue(
unsigned vector,
ppc_exc_category category,
uint32_t *prologue,
size_t *prologue_size
@@ -152,7 +155,14 @@ rtems_status_code ppc_exc_make_prologue(
memcpy(prologue, prologue_template, prologue_template_size);
- if (!ppc_exc_create_branch_op(vector, prologue, prologue_template_size)) {
+ if (
+ !ppc_exc_create_branch_op(
+ vector,
+ vector_base,
+ prologue,
+ prologue_template_size
return RTEMS_INVALID_ADDRESS;
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
index a275d2e..bec81c1 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
@@ -303,32 +303,12 @@ static inline bool ppc_exc_is_valid_category(ppc_exc_category category)
- * @brief Indicates if exception entry table resides in a writable memory.
+ * @brief Returns the entry address of the vector.
- * This variable is initialized to 'TRUE' by default;
- * BSPs which have their vectors in ROM should set it
- * to FALSE prior to initializing raw exceptions.
- * I suspect the only candidate is the simulator.
- * After all, the value of this variable is used to
- * determine where to install the prologue code and
- * installing to ROM on anyting that's real ROM
- * will fail anyways.
- * This should probably go away... (T.S. 2007/11/30)
-extern bool bsp_exceptions_in_RAM;
- * @brief Vector base address for CPUs (for example e200 and e500) with IVPR
- * and IVOR registers.
+ * @param[in] vector The vector number.
+ * @param[in] vector_base The vector table base address.
-extern uint32_t ppc_exc_vector_base;
- * @brief Returns the entry address of the vector @a vector.
-void *ppc_exc_vector_address(unsigned vector);
+void *ppc_exc_vector_address(unsigned vector, void *vector_base);
* @brief Returns the category set for a CPU of type @a cpu, or @c NULL if
@@ -358,8 +338,8 @@ ppc_exc_category ppc_exc_category_for_vector(
* @brief Makes a minimal prologue for the vector @a vector with the category
* @a category.
- * The minimal prologue will be copied to @a prologue. Not more than @a
- * prologue_size bytes will be copied. Returns the actual minimal prologue
+ * The minimal prologue will be copied to @a prologue. Not more than
+ * @a prologue_size bytes will be copied. Returns the actual minimal prologue
* size in bytes in @a prologue_size.
* @retval RTEMS_SUCCESSFUL Minimal prologue successfully made.
@@ -369,6 +349,7 @@ ppc_exc_category ppc_exc_category_for_vector(
unsigned vector,
uint32_t *prologue,
@@ -377,6 +358,18 @@ rtems_status_code ppc_exc_make_prologue(
* @brief Initializes the exception handling.
+ * @see ppc_exc_initialize().
+ uint32_t interrupt_disable_mask,
+ uintptr_t interrupt_stack_begin,
+ void *vector_base
+ * @brief Initializes the exception handling.
* If the initialization fails, then this is a fatal error. The fatal error
* source is RTEMS_FATAL_SOURCE_BSP_GENERIC and the fatal error code is
* BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION.
@@ -387,11 +380,19 @@ rtems_status_code ppc_exc_make_prologue(
* SVR4/EABI, or
* - the minimal prologue creation failed.
+static inline void ppc_exc_initialize(
+ interrupt_disable_mask,
+ interrupt_stack_begin,
+ interrupt_stack_size,
+ NULL
* @brief High-level exception handler type.
1.7.7
