[PATCH 1/5] bsps: Move bsp_generic_fatal_code to new file
Sebastian Huber
Thu Jun 20 10:06:08 UTC 2013
Add bsp_generic_fatal().
c/src/lib/libbsp/Makefile.am | 1 +
c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c | 7 +--
c/src/lib/libbsp/preinstall.am | 4 ++
c/src/lib/libbsp/shared/include/bootcard.h | 13 +-----
c/src/lib/libbsp/shared/include/generic-fatal.h | 42 ++++++++++++++++++++
c/src/lib/libbsp/shared/src/irq-generic.c | 7 +--
.../new-exceptions/bspsupport/ppc_exc_initialize.c | 7 +--
cpukit/score/include/rtems/score/interr.h | 6 +-
8 files changed, 58 insertions(+), 29 deletions(-)
create mode 100644 c/src/lib/libbsp/shared/include/generic-fatal.h
diff --git a/c/src/lib/libbsp/Makefile.am b/c/src/lib/libbsp/Makefile.am
index 60a0d49..5e27b5b 100644
--- a/c/src/lib/libbsp/Makefile.am
+++ b/c/src/lib/libbsp/Makefile.am
@@ -33,6 +33,7 @@ include_bspdir = $(includedir)/bsp
include_bsp_HEADERS =
include_bsp_HEADERS += shared/include/default-initial-extension.h
+include_bsp_HEADERS += shared/include/generic-fatal.h
include $(srcdir)/preinstall.am
include $(top_srcdir)/automake/subdirs.am
diff --git a/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c b/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
index c9c94fe..1b659f0 100644
--- a/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
+++ b/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
@@ -15,7 +15,7 @@
#include <bsp.h>
-#include <bsp/bootcard.h>
+#include <bsp/generic-fatal.h>
const char * const _Spurious_Error_[] = {"Reset","Bus Error","Address Error",
@@ -72,10 +72,7 @@ rtems_isr Spurious_Isr(
RAW_PUTI(sp);
RAW_PUTS("\n\r");
#endif
- rtems_fatal(
- RTEMS_FATAL_SOURCE_BSP_GENERIC,
- BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
+ bsp_generic_fatal( BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT );
void Spurious_Initialize(void)
diff --git a/c/src/lib/libbsp/preinstall.am b/c/src/lib/libbsp/preinstall.am
index f4f0fa4..07c18f1 100644
--- a/c/src/lib/libbsp/preinstall.am
+++ b/c/src/lib/libbsp/preinstall.am
@@ -22,3 +22,7 @@ $(PROJECT_INCLUDE)/bsp/default-initial-extension.h: shared/include/default-initi
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/default-initial-extension.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/default-initial-extension.h
+$(PROJECT_INCLUDE)/bsp/generic-fatal.h: shared/include/generic-fatal.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/generic-fatal.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/generic-fatal.h
diff --git a/c/src/lib/libbsp/shared/include/bootcard.h b/c/src/lib/libbsp/shared/include/bootcard.h
index f3de760..ca27832 100644
--- a/c/src/lib/libbsp/shared/include/bootcard.h
+++ b/c/src/lib/libbsp/shared/include/bootcard.h
@@ -7,10 +7,10 @@
- * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2008-2013 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
- * Obere Lagerstr. 30
+ * Dornierstr. 4
* 82178 Puchheim
* Germany
* <rtems at embedded-brains.de>
@@ -51,15 +51,6 @@ extern "C" {
- * @brief Generic BSP fatal error codes.
-typedef enum {
- BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION,
- BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION,
-} bsp_generic_fatal_code;
* @brief Global pointer to the command line of boot_card().
extern const char *bsp_boot_cmdline;
diff --git a/c/src/lib/libbsp/shared/include/generic-fatal.h b/c/src/lib/libbsp/shared/include/generic-fatal.h
new file mode 100644
index 0000000..4edf467
--- /dev/null
+++ b/c/src/lib/libbsp/shared/include/generic-fatal.h
@@ -0,0 +1,42 @@
+ * Copyright (c) 2012-2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef LIBBSP_SHARED_BSP_GENERIC_FATAL_H
+#define LIBBSP_SHARED_BSP_GENERIC_FATAL_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Generic BSP fatal error codes.
+typedef enum {
+ BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION,
+ BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION,
+ BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
+} bsp_generic_fatal_code;
+static inline void bsp_generic_fatal( bsp_generic_fatal_code code )
+ rtems_fatal( RTEMS_FATAL_SOURCE_BSP_GENERIC, (rtems_fatal_code) code );
+#ifdef __cplusplus
+#endif /* LIBBSP_SHARED_BSP_GENERIC_FATAL_H */
diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
index 5cf9c91..b2d712a 100644
--- a/c/src/lib/libbsp/shared/src/irq-generic.c
+++ b/c/src/lib/libbsp/shared/src/irq-generic.c
@@ -23,7 +23,7 @@
#include <bsp/irq-generic.h>
@@ -170,10 +170,7 @@ void bsp_interrupt_initialize(void)
sc = bsp_interrupt_facility_initialize();
if (sc != RTEMS_SUCCESSFUL) {
- rtems_fatal(
+ bsp_generic_fatal(BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION);
bsp_interrupt_set_initialized();
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
index 6ac9880..d0f9116 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
@@ -25,7 +25,7 @@
#include <bsp/vectors.h>
#define PPC_EXC_ASSERT_OFFSET(field, off) \
RTEMS_STATIC_ASSERT( \
@@ -145,10 +145,7 @@ static void ppc_exc_initialize_booke(void *vector_base)
static void ppc_exc_fatal_error(void)
- rtems_fatal(
+ bsp_generic_fatal(BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION);
void ppc_exc_initialize_with_vector_base(
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index a047ca6..79edc21 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -71,10 +71,10 @@ typedef enum {
* @brief Fatal source for generic BSP errors.
- * The fatal codes are defined in <bsp/bootcard.h>. Examples are interrupt
- * and exception initialization.
+ * The fatal codes are defined in <bsp/generic-fatal.h>. Examples are
+ * interrupt and exception initialization.
- * @see bsp_generic_fatal_code.
+ * @see bsp_generic_fatal_code and bsp_generic_fatal().
1.7.7
