RTEMS_malta board support
Joel Sherrill
Joel.Sherrill at OARcorp.com
Thu Jun 20 11:22:15 UTC 2013
What tools did you use?
You must use 4.11 tools with the git master.
"CHINTHA MOL C.S." <chintha308 at gmail.com> wrote:
Hi,
I would like to port RTEMS to mips -malta board.
I tried to build RTEMS version 4.10.99 , but i encountered many issues while building.
while searching on net i found that RTEMS stable version released is 4.10.2, but it does not have malta support.
Could you please suggest the stable RTEMS version which have support for malta board.
Regards,
Chintha
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130620/3ac44d2e/attachment.html>
