RTEMS_malta board support
Thu Jun 20 13:33:03 UTC 2013
The git master branch (referred to as 4.11 or 4.10.99) is mostly
stable. I think it should be released as 4.11 soon, but there are a
few small technical and personnel availability issues to overcome.
On Thu, Jun 20, 2013 at 7:22 AM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> What tools did you use?
> You must use 4.11 tools with the git master.
> "CHINTHA MOL C.S." <chintha308 at gmail.com> wrote:
> Hi,
> I would like to port RTEMS to mips -malta board.
> I tried to build RTEMS version 4.10.99 , but i encountered many issues while
> building.
> while searching on net i found that RTEMS stable version released is 4.10.2,
> but it does not have malta support.
> Could you please suggest the stable RTEMS version which have support for
> malta board.
> Regards,
> Chintha
> rtems-devel mailing list
> rtems-devel at rtems.org
