globaledf
Fri Jun 21 01:07:04 UTC 2013
Cc:rtems-devel
When modifying the build system i.e. Makefile.am files, you need to rerun
the bootstrap script and maybe with the -p flag if you add new header
files. Run bootstrap in the nearest directory to the modified Makefile.am
that contains a configure.ac file. Then recompile rtems.
-Gedare
On Jun 20, 2013 6:06 PM, "Sree Harsha Konduri" <sreehars at buffalo.edu> wrote:
> hey Gedare,
> i am facing an issue in verifying the globaledf template that i am adding
> with a functionality of simplesmp scheduler.
> although i added the includes in $r/cpukit/score/Makefile.am
> when i compile the smp01 test with the globaledf macro i get a file not
> found error for schedulerglobaledf.h in include/rtems/score.
> The file is present in the location? can you share your view , is there
> something i am missing?
> Thanks,
> Harsha
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130620/02724c98/attachment.html>
