globaledf
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Jun 21 10:05:15 UTC 2013
On 06/21/2013 03:07 AM, Gedare Bloom wrote:
> Cc:rtems-devel
> When modifying the build system i.e. Makefile.am files, you need to
> rerun the bootstrap script and maybe with the -p flag if you add new
> header files. Run bootstrap in the nearest directory to the modified
> Makefile.am that contains a configure.ac <http://configure.ac> file.
> Then recompile rtems.
Make sure to have RTEMS autoconf and automake in $PATH,
then pass --enable-maintainer-mode to configure
then running make will automatically take care about this in most cases.
Ralf
