RTEMS_malta board support
CHINTHA MOL C.S.
chintha308 at gmail.com
Tue Jun 25 11:20:10 UTC 2013
Hi all,
I would like to port RTEMS to malta mips evaluation board.
I successfully built RTEMS 4.10.99 with malta BSP.
I need to load the generated hello.ralf to malta board with YAMON
bootloader.
I edited the MIPS Malta linker script .
RAM base is changed from 0x80000000 to 0x800c0000. and section start from
0x80010000 to 0x80100000.
I converted the hello.ralf file to srec format using mips-retms4.11-objcopy
and successfully loaded it via tftp. But while running it, exception in TLB
occures. the error log is given below.
How can i successfully run this rtems-application (hello.ralf) in malta
board?
Compilation time = Dec 7 2006
19:00:35
Board type/revision = 0x02 (Malta) /
0x00
Core board type/revision = 0x01 (CoreLV) /
0x01
System controller/revision = Galileo /
GT_64120A-B-2
FPGA revision =
0x0001
MAC address =
00.d0.a0.00.05.e9
Board S/N =
0000001245
PCI bus frequency = 33.33
MHz
Processor Company ID/options = 0x01 (MIPS Technologies, Inc.) /
0x80
Processor ID/revision = 0x90 (MIPS 4KEc) /
0x68
Endianness =
Little
CPU/Bus frequency = 240 MHz / 80
MHz
Flash memory size = 4
MByte
SDRAM size = 128
MByte
First free SDRAM address = 0x800b7350
YAMON>
load
About to load tftp://10.1.125.98/hello.srec
Press Ctrl-C to
break
Start = 0x80100024, range = (0x80100000,0x801348a7), format =
SREC
YAMON> go 0x80100024
* Exception (user) : TLB (store)
BadVAddr = 0x00004234 Cause =
0xd080800c
Compare = 0xced7cdbf Config =
0x80250483
Config1 = 0xbe994c8e Config2 =
0x80000000
Config3 = 0x00000020 Context =
0xdf800020
Count = 0xc21f9d1d DEPC =
0xdf5f1e43
Debug = 0x0e017c3f EBase =
0x80000000
EPC = 0x80100050 EntryHi =
0x000040ff
EntryLo0 = 0x01f7f555 EntryLo1 =
0x01bf36d7
ErrorEPC = 0xbfc00380 HWREna =
0x00000000
Index = 0x80000014 IntCtl =
0xe0000000
PRId = 0x80019068 PageGrain =
0x00000000
PageMask = 0x19ffe000 Random =
0x0000001e
SRSCtl = 0x00000000 SRSMap =
0x00000000
Status = 0x00002c02 WatchHi =
0x00000000
WatchLo = 0x00000000 Wired =
0x00000000
Hi = 0x00000000 Lo =
0x80100020
$ 0(zr):0x00000000 $ 8(t0):0x00000000 $16(s0):0x00000000
$24(t8):0x00000000
$ 1(at):0x00000000 $ 9(t1):0x00000000 $17(s1):0x00000000
$25(t9):0x00000000
$ 2(v0):0x00000000 $10(t2):0x00000000 $18(s2):0x00000000
$26(k0):0x00000000
$ 3(v1):0x00000000 $11(t3):0x00000000 $19(s3):0x00000000
$27(k1):0x800abf20
$ 4(a0):0x00000001 $12(t4):0x00000000 $20(s4):0x00000000
$28(gp):0x00000000
$ 5(a1):0x800ad268 $13(t5):0x00000000 $21(s5):0x00000000
$29(sp):0x800b7340
$ 6(a2):0x8006dccc $14(t6):0x00000000 $22(s6):0x00000000
$30(s8):0x800b7340
$ 7(a3):0x08000000 $15(t7):0x00000000 $23(s7):0x00000000
$31(ra):0x8003ca34
Regards,
Chintha
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130625/0ebb8fa2/attachment.html>
