Source builder
Chris Johns
chrisj at rtems.org
Fri Jun 7 00:23:52 UTC 2013
Claus, Ric wrote:
> I tried the Source Builder:
> $ ../source-builder/sb-set-builder --log=l-arm.log --prefix /u1/reg/package/gnu/rtems-4.11_new 4.11/rtems-arm
> RTEMS Source Builder - Set Builder, v0.2.0
> Build Set: 4.11/rtems-arm
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> Creating source directory: sources
> download: http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz -> sources/expat-2.1.0.tar.gz
> building: expat-2.1.0-x86_64-linux-gnu-1
> config: tools/rtems-binutils-2.23.2-1.cfg
> package: arm-rtems4.11-binutils-2.23.2-1
> download: ftp://ftp.gnu.org/gnu/binutils/binutils-2.23.2.tar.bz2 -> sources/binutils-2.23.2.tar.bz2
> building: arm-rtems4.11-binutils-2.23.2-1
> config: tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
> package: arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1
> download: ftp://ftp.gnu.org/gnu/gcc/gcc-4.8.1/gcc-4.8.1.tar.bz2 -> sources/gcc-4.8.1.tar.bz2
> Creating source directory: sources/cvs
> Creating source directory: sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_31_May_2013
> cvs: checkout: cvs://pserver:anoncvs@sourceware.org/cvs/src -> sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_31_May_2013
> cvs: reset: cvs://pserver:anoncvs@sourceware.org/cvs/src
> Creating source directory: patches
> download: http://git.rtems.org/rtems-tools/plain/tools/4.11/newlib/newlib-sys-signal-20130532.diff -> patches/newlib-sys-signal-20130532.diff
> download: http://www.mpfr.org/mpfr-3.0.1/mpfr-3.0.1.tar.bz2 -> sources/mpfr-3.0.1.tar.bz2
> download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz -> sources/mpc-0.8.2.tar.gz
> download: ftp://ftp.gnu.org/gnu/gmp/gmp-5.0.5.tar.bz2 -> sources/gmp-5.0.5.tar.bz2
> building: arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1
> Build Set: Time 1:04:32.687254
> error: shell cmd failed: /bin/sh -ex /u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/doit
> Build FAILED
> $ uname -a
> Linux rddev110 2.6.32-358.6.2.el6.x86_64 #1 SMP Tue May 14 15:48:21 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
> Apparently the log file is too big to send by e-mail. Here is the final snippet:
> make[2]: Entering directory `/u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/build/gcc'
> TARGET_CPU_DEFAULT="" \
> HEADERS="auto-host.h ansidecl.h" DEFINES="" \
> /bin/sh ../../gcc-4.8.1/gcc/mkconfig.sh config.h
> TARGET_CPU_DEFAULT="TARGET_CPU_generic" \
> HEADERS="options.h insn-constants.h config/dbxelf.h config/elfos.h config/arm/unknown-elf.h config/arm/elf.h config/arm/bpabi.h config/rtems.h config/arm/rtems-eabi
> .h config/newlib-stdint.h config/arm/aout.h config/vxworks-dummy.h config/arm/arm.h config/initfini-array.h defaults.h" DEFINES="LIBC_GLIBC=1 LIBC_UCLIBC=2 LIBC_BIONIC=3" \
> /bin/sh ../../gcc-4.8.1/gcc/mkconfig.sh tm.h
> gawk -f ../../gcc-4.8.1/gcc/opt-gather.awk ../../gcc-4.8.1/gcc/ada/gcc-interface/lang.opt ../../gcc-4.8.1/gcc/fortran/lang.opt ../../gcc-4.8.1/gcc/go/lang.opt ../../gcc-4.8
> .1/gcc/java/lang.opt ../../gcc-4.8.1/gcc/lto/lang.opt ../../gcc-4.8.1/gcc/c-family/c.opt ../../gcc-4.8.1/gcc/common.opt ../../gcc-4.8.1/gcc/config/arm/arm-tables.opt ../../
> gcc-4.8.1/gcc/config/arm/arm.opt ../../gcc-4.8.1/gcc/config/rtems.opt> tmp-optionlist
> /bin/sh ../../gcc-4.8.1/gcc/mkconfig.sh bconfig.h/usr/bin/g++ -O2 -pipe -I/u1/reg/package/rtems-source-builder/rtems/build/tmp/sb-claus/4.11/rtems-arm/u1/reg/package/gnu/rtems-4.11_new/include -L/u1/reg/package/rtems-sour
> ce-builder/rtems/build/tmp/sb-claus/4.11/rtems-arm/u1/reg/package/gnu/rtems-4.11_new/lib -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasyn
> chronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -DGENERATOR_FILE -I. -Ibuild -I../../gcc-4.8.1/gcc -I../../gcc-4.8.1/gcc/build -I../../gcc-4.8.1/gcc/../include -I../../gcc-4.8.1/gcc/../libcpp/include -I/u1/reg/package
> /rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/build/./gmp -I/u1/reg/package/rtems-source
> -builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/gcc-4.8.1/gmp -I/u1/reg/package/rtems-source-builder/rt
> ems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/build/./mpfr -I/u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/gcc-4.8.1/mpfr -I/u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/gcc-4.8.1/mpc/src -I../../gcc-4.8.1/gcc/../libdecnumber -I../../gcc-4.8.1/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.1/gcc/../libbacktrace \
> -DBASEVER="\"4.8.1\"" -DDATESTAMP="\" 20130531\"" \
> -DREVISION="\"\"" \
> -DDEVPHASE="\" (RTEMS 4.11-RSB(8113b768b099e9850e558a85da2fab52030e0885)-1,gcc-4.8.1/newlib-31-May-2013)\"" -DPKGVERSION="\"(GCC) \"" \
> -DBUGURL="\"<http://gcc.gnu.org/bugs.html>\"" -o build/version.o ../../gcc-4.8.1/gcc/version.c
> /u1/reg/package/rtems-source-builder/rtems/build/tmp/sb-claus/4.11/rtems-arm/u1/reg/package/gnu/rtems-4.11_new/bin/arm-rtems4.11-as: unrecognized option '-Qy'
This looks like a native host compile. Why would the native compiler
invoke the arm cross assembler ?
> ../../gcc-4.8.1/gcc/version.c:35: fatal error: error closing -: Broken pipe
> compilation terminated.
> The bug is not reproducible, so it is likely a hardware or OS problem.
> make[2]: *** [build/version.o] Error 1
> make[2]: *** Waiting for unfinished jobs....
> /bin/sh ../../gcc-4.8.1/gcc/../move-if-change tmp-optionlist optionlist
> echo timestamp> s-options
> make[2]: Leaving directory `/u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/build/gcc'
> make[1]: *** [all-gcc] Error 2
> make[1]: Leaving directory `/u1/reg/package/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1/arm-rtems4.11-gcc-4.8.1-newlib-31-May-2013-1-4.8.1/build'
> make: *** [all] Error 2
> Any ideas?
> As you can see, this came after an hour of waiting for it to complete. Some files take a loooonnnngggg time to download, during which it is not apparent that there is any activity. Initially I killed the process because I figured it was stuck. Some form of progress indicator would be nice.
> Thanks,
> Ric
> rtems-devel mailing list
> rtems-devel at rtems.org
