[PATCH 03/12] score: Add and use _Thread_Dispatch_if_necessary()
Wed Jun 12 15:12:29 UTC 2013
Delete _Thread_Evaluate_is_dispatch_needed().
Use _Thread_Dispatch_is_enabled() in rtems_task_mode() instead of the
system state to determine if a thread dispatch is allowed.  Signales are
now delivered in rtems_task_mode() even if preemption is disabled.  This
is in line with rtems_signal_send().
 cpukit/rtems/src/taskmode.c                |    5 +--
 cpukit/score/inline/rtems/score/thread.inl |   52 ++++++++++++++--------------
 2 files changed, 27 insertions(+), 30 deletions(-)
diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
index 66cf505..7b3233e 100644
--- a/cpukit/rtems/src/taskmode.c
+++ b/cpukit/rtems/src/taskmode.c
@@ -100,10 +100,7 @@ rtems_status_code rtems_task_mode(
-  if ( _System_state_Is_up( _System_state_Get() ) ) {
-     if (_Thread_Evaluate_is_dispatch_needed( needs_asr_dispatching ) )
-      _Thread_Dispatch();
+  _Thread_Dispatch_if_necessary( executing, needs_asr_dispatching );
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/inline/rtems/score/thread.inl b/cpukit/score/inline/rtems/score/thread.inl
index e6e1929..4576dea 100644
--- a/cpukit/score/inline/rtems/score/thread.inl
+++ b/cpukit/score/inline/rtems/score/thread.inl
@@ -223,6 +223,32 @@ RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_global_exit_status( void )
+ * @brief Issues a thread dispatch if necessary.
+ * @param[in] executing The executing thread.
+ * @param[in] needs_asr_dispatching Indicates whether or not the API
+ *            level signals are pending and a dispatch is necessary.
+RTEMS_INLINE_ROUTINE void _Thread_Dispatch_if_necessary(
+  Thread_Control *executing,
+  bool            needs_asr_dispatching
+  if ( _Thread_Dispatch_is_enabled() ) {
+    bool dispatch_necessary = needs_asr_dispatching;
+    if ( !_Thread_Is_heir( executing ) && executing->is_preemptible ) {
+      dispatch_necessary = true;
+      _Thread_Dispatch_necessary = dispatch_necessary;
+    if ( dispatch_necessary ) {
+      _Thread_Dispatch();
  * This routine returns the C library re-enterant pointer.
@@ -242,32 +268,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Set_libc_reent (
   _Thread_libc_reent = libc_reent;
- * This routine evaluates the current scheduling information for the
- * system and determines if a context switch is required.  This
- * is usually called after changing an execution mode such as preemptability
- * for a thread.
- * @param[in] are_signals_pending specifies whether or not the API
- *            level signals are pending and a dispatch is needed.
-RTEMS_INLINE_ROUTINE bool _Thread_Evaluate_is_dispatch_needed(
-  bool are_signals_pending
-  Thread_Control     *executing;
-  executing = _Thread_Executing;
-  if ( are_signals_pending ||
-       (!_Thread_Is_heir( executing ) && executing->is_preemptible) ) {
-    _Thread_Dispatch_necessary = true;
-    return true;
-  return false;
 #endif
1.7.7
