Gsoc2013-Atomic_Project-Status
Sebastian Huber
Mon Jun 24 08:16:57 UTC 2013
Hello Wei,
great, you have now a good development environment.
I work currently on a requirements document for the atomic operations API. It
was not really clear what we need for the SMP support in RTEMS, but since I
worked on this topic the last couple of months I have now a better
understanding of the requirements.
Hopefully we can implement the ticket locks for example in
http://git.rtems.org/rtems/tree/cpukit/score/cpu/powerpc/rtems/score/cpusmplock.h
http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/rtems/score/cpusmplock.h
with the atomic operations and get sufficiently efficient code.
Other applications are a phase-fair read-write lock (for example to read and
update the ticks since boot), a sense barrier or lock-free updates of heir to
executing thread changes.
On 06/22/2013 03:59 PM, Deng Hengyi wrote:
> Hi all,
> This is a brief status report about my GSOC2013 project ----- atomic ops support for RTEMS.
> DONE:
> 1. Setup the development environment including the latest rtems git repo, rtems-test git repo and qemu for realview_pbx_a9.
> 2. Build the latest rtems toolchains which include the stdatomic.h support.
> 3. Modify the existing atomic API to be compatible with C11 std atomic.h.
> 4. Replace the existing atomic SMP implementation with stdatomic.h.
> 5. Build the spatomic and smpatomic test case for realview_pbx_a9 SMP and UP.
> 6. All the spatomic and smpatomic have been passed.
> 7. Have submit the patches to devel list to be reviewed.
> TODO.
> 1. Plan to integrate the patches into mainline.
> 2. Support the stdatomic.h for other architectures such as PowerPC, Mips and Sparc.
> 3. Add the detection for whether support stdatomic.h for some architectures.
> WeiY
> Best Regards
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
