[Patch] Removing legacy method from arm csb336
Sebastian Huber
Thu Jun 27 08:18:03 UTC 2013
On 06/26/2013 05:28 PM, Vipul Nayyar wrote:
> For my GSOC Project Unified APIs, a public google doc has been setup (
> https://docs.google.com/document/d/1W9DMnpocXUKXiQMxHbbp0aG-ecuh94P-3N7hxEJmcgs/edit?usp=sharing)
> for community viewing. In order to establish this unified pattern across all
> BSPs, I felt that deprecated methods stored in irq-legacy.c should be dealt
> with first. So, I'm attaching a very basic patch which removes the deprecated
> method BSP_install_rtems_irq_handler from arm csb336 and instead makes use
> of rtems_interrupt_handler_install, as suggested in irq-legacy.c. Please do
> give suggestions if I'm heading the right way, and any modifications that this
> patch may require.
I would not touch the existing code that uses these legacy functions. The
irq-legacy.c is provided to keep existing code as is.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
