[Patch] Removing legacy method from arm csb336
Vipul Nayyar nayyar_vipul at yahoo.com
Thu Jun 27 08:40:09 UTC 2013
Hello,
According to the discussions with my mentor Joel Sherill, I was suggested to kill all legacy/deprecated API uses in the tree which are defined in irq-legacy.c as part of my project. I guess Dr Joel can guide us better whether all of the deprecated methods need to be removed or only some of them. cc'ing Dr Joel for guidance on this.
Regards
Vipul Nayyar
________________________________
 From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: rtems-devel at rtems.org
Sent: Thursday, 27 June 2013 1:48 PM
Subject: Re: [Patch] Removing legacy method from arm csb336
On 06/26/2013 05:28 PM, Vipul Nayyar wrote:
> For my GSOC Project Unified APIs,  a public google doc has been setup (
> https://docs.google.com/document/d/1W9DMnpocXUKXiQMxHbbp0aG-ecuh94P-3N7hxEJmcgs/edit?usp=sharing)
> for community viewing. In order to establish this unified pattern across all
> BSPs, I felt that deprecated methods stored in irq-legacy.c should be dealt
> with first. So, I'm attaching a very basic patch which removes the deprecated
> method BSP_install_rtems_irq_handler from arm csb336 and instead makes use
> of rtems_interrupt_handler_install, as suggested in irq-legacy.c. Please do
> give suggestions if I'm heading the right way, and any modifications that this
> patch may require.
I would not touch the existing code that uses these legacy functions.  The irq-legacy.c is provided to keep existing code as is.
-- Sebastian Huber, embedded brains GmbH
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
E-Mail  : sebastian.huber at embedded-brains.de
PGP     : Public key available on request.
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130627/31051555/attachment-0001.html>
