[Patch] Removing legacy method from arm csb336
Vipul Nayyar nayyar_vipul at yahoo.com
Sat Jun 29 18:53:15 UTC 2013
Hello,
Thanks for guidance on the previous patch. I hope I've rectified them in the following patch. I was wondering that while checking the return value of the functions with assert() , I need to include <assert.h> . So, should I include it individually in both the files, or somewhere else ? Please do suggest any other changes that maybe required.
commit 70aee0d8827888b5c8230f45594e85fda5bd5a6d
Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
Date:   Sun Jun 30 00:17:44 2013 +0530
    Updated Legacy code in arm csb336
diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
index 4dc409b..c0505bb 100644
--- a/c/src/lib/libbsp/arm/csb336/console/uart.c
+++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
@@ -247,8 +247,28 @@ static int imx_uart_first_open(int major, int minor, void *arg)
     imx_uart_data[minor].tty   = args->iop->data1;
 #if defined(USE_INTERRUPTS)
-    BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
-    BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+    assert(rtems_interrupt_handler_install(
+      imx_uart_tx_isr_data[minor].name,
+      "Consle",
+      RTEMS_INTERRUPT_UNIQUE,
+      imx_uart_tx_isr_data[minor].hdl,
+      imx_uart_tx_isr_data[minor].handle
+     ) == RTEMS_SUCCESSFUL
+    if (imx_uart_tx_isr_data[minor].on != NULL) {
+    imx_uart_tx_isr_data[minor].on(&imx_uart_tx_isr_data[minor]);
+      imx_uart_rx_isr_data[minor].name,
+      "Console",
+      imx_uart_rx_isr_data[minor].hdl,
+      imx_uart_rx_isr_data[minor].handle
+    if (imx_uart_rx_isr_data[minor].on != NULL) {
+    imx_uart_rx_isr_data[minor].on(&imx_uart_rx_isr_data[minor]);
     imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
 #endif
@@ -259,8 +279,24 @@ static int imx_uart_first_open(int major, int minor, void *arg)
 static int imx_uart_last_close(int major, int minor, void *arg)
-    BSP_remove_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
-    BSP_remove_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+    if (imx_uart_tx_isr_data[minor].off != NULL) {
+    imx_uart_tx_isr_data[minor].off(&imx_uart_tx_isr_data[minor]);
+    assert( rtems_interrupt_handler_remove(
+    if (imx_uart_rx_isr_data[minor].off != NULL) {
+    imx_uart_rx_isr_data[minor].off(&imx_uart_rx_isr_data[minor]);
 #endif
     return 0;
diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
index e513595..9ae970e 100644
--- a/c/src/lib/libbsp/arm/csb336/network/network.c
+++ b/c/src/lib/libbsp/arm/csb336/network/network.c
@@ -334,7 +334,17 @@ void  mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
     MC9328MXL_GPIOA_IMR |= bit(3);
     /* Install the interrupt handler */
-    BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
+      mc9328mxl_enet_isr_data.name,
+      "Network",
+      mc9328mxl_enet_isr_data.hdl,
+      mc9328mxl_enet_isr_data.handle
+    if (mc9328mxl_enet_isr_data.on != NULL) {
+    mc9328mxl_enet_isr_data.on(&mc9328mxl_enet_isr_data);
 } /* mc9328mxl_enet_init_hw() */
Regards
Vipul Nayyar
________________________________
To: Gedare Bloom <gedare at rtems.org>
Cc: Vipul Nayyar <nayyar_vipul at yahoo.com>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Friday, 28 June 2013 2:18 AM
Subject: Re: [Patch] Removing legacy method from arm csb336
I agree with you Gedare. The legacy api support remains for a while. There is external code which could use it and we always hold legacy for at least one release branch.
I just want the code in the tree to use the new way consistently. And update check_submission to flag the old way
Gedare Bloom <gedare at rtems.org> wrote:
On Thu, Jun 27, 2013 at 4:46 AM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> The goal of this is to kill bad examples. It is legacy and we don't want
> people to use it anymore. These should be mechanical changes. Vipul should
> be able to provide instructions for users with external drivers to make the
> changes.
> Fixing these could break here or there but if we don't remove uses of
> deprecated methods then users will use them in new BSPs and that is
> unacceptable.
I'd prefer to see 4.11 released before we start killing off legacy support.
> Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
> Hello,
> According to the discussions with my mentor Joel Sherill, I was suggested to
> kill all legacy/deprecated API uses in the tree which are defined in
> irq-legacy.c as part of my project. I guess Dr Joel can guide us better
> whether all of the deprecated methods need to be removed or only some of
> them. cc'ing Dr Joel for guidance on this.
> Regards
> Vipul Nayyar
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> To: rtems-devel at rtems.org
> Sent: Thursday, 27 June 2013 1:48 PM
> On 06/26/2013 05:28 PM, Vipul Nayyar wrote:
>> For my GSOC Project Unified APIs,  a public google doc has been setup (
>> https://docs.google.com/document/d/1W9DMnpocXUKXiQMxHbbp0aG-ecuh94P-3N7hxEJmcgs/edit?usp=sharing)
>> for community viewing. In order to establish this unified pattern across
>> all
>> BSPs, I felt that deprecated methods stored in irq-legacy.c should be
>> dealt
>> with first. So, I'm attaching a very basic patch which removes the
>> deprecated
>> method BSP_install_rtems_irq_handler from arm csb336 and instead makes use
>> of rtems_interrupt_handler_install, as suggested in irq-legacy.c. Please
>> do
>> give suggestions if I'm heading the right way, and any modifications that
>> this
>> patch may require.
> I would not touch the existing code that uses these legacy functions.  The
> irq-legacy.c is provided to keep existing code as is.
> -- Sebastian Huber, embedded brains GmbH
> Phone  : +49 89 189 47 41-16
> Fax    : +49 89 189 47 41-09
> E-Mail  : sebastian.huber at embedded-brains.de
> PGP    : Public key available on request.
> rtems-devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130630/11ec2460/attachment-0001.html>
